unfortunately, getting error for libcamera-hello command.
libcamera-hello
Preview window unavailable
[0:00:45.901056749] [1251] INFO Camera camera_manager.cpp:299 libcamera v0.0.0+4226-8689dd6b
[0:00:45.936961527] [1253] WARN CameraSensorProperties camera_sensor_properties.cpp:243 No static properties available for 'arducam-pivariety'
[0:00:45.937021231] [1253] WARN CameraSensorProperties camera_sensor_properties.cpp:245 Please consider updating the camera sensor properties database
[0:00:45.952268231] [1253] ERROR IPAProxy ipa_proxy.cpp:149 Configuration file 'arducam-pivariety.json' not found for IPA module 'raspberrypi'
[0:00:46.284776119] [1253] INFO RPI raspberrypi.cpp:1485 Registered camera /base/soc/i2c0mux/i2c@1/arducam_pivariety@c to Unicam device /dev/media3 and ISP device /dev/media0
[0:00:46.285592897] [1251] INFO Camera camera.cpp:1028 configuring streams: (0) 2672x2008-YUV420
[0:00:46.339167008] [1253] INFO RPI raspberrypi.cpp:851 Sensor: /base/soc/i2c0mux/i2c@1/arducam_pivariety@c - Selected sensor format: 2656x2004-SRGGB10_1X10 - Selected unicam format: 2656x2004-pRAA
[0:00:46.363584360] [1259] WARN IPARPI raspberrypi.cpp:811 Could not set AF_MODE - no AF algorithm
Segmentation fault
pkg -l | grep libcamera
ii libcamera-apps 0~git20230309+4def288-1 arm64 libcamera-apps
ii libcamera-dev:arm64 0~git20230512+8689dd6b-1 arm64 complex camera support library (development files)
ii libcamera0:arm64 0~git20230512+8689dd6b-1 arm64 complex camera support library
ii python3-libcamera 0~git20230302+923f5d70-1 arm64 complex camera support library (Python 3 bindings)
