20230922
ACM-16886
Raspi4 bullseye kernel code branch is 6.1.y
I patched ov9281.c driver following this datasheet https://www.v-visiontech.com/web/userfiles/download/OV9281_CSP5_DS_1.01.pdf
But external trigger does not work
I have tried this too ArduCAM/MIPI_Camera/ RPI/ov9281_external_trigger.c#L16
But no success…
- Problems you were having?
External trigger does not work
Log shows that driver is loaded, camera works fine in normal mode however does not work in external trigger mode as it is not supported in driver
I patched driver to use external trigger similar to this media: i2c: ov7251: Add module param to select ext trig mode · raspberrypi/linux@e6a7eed · GitHub
- What help do you need?
I need valid datasheet for camera so I can implement external trigger support in ov9281 driver
Or perhaps code that shows external trigger works
