Arducam OV2311 Jetvariety driver loads IMX219 on Jetson Xavier NX JNX30M JetPack 4.6.2
Hi everyone, I’m stuck trying to get the Jetvariety driver installed for an OV2311 camera and I’ve basically run out of ideas. I’m running it on a Jetson Xavier NX with a JNX30M carrier board (custom firmware from the board maker), JetPack 4.6.2 (4.9.253-tegra), booting from the onboard 16GB eMMC.
I followed the guide at Redirecting... and ran install_full.sh, which finished with no installation errors. Then I rebooted and checked with:
dmesg | grep imx219
dmesg | grep arducam
The imx219 command returned output, but the arducam one returned nothing at all. So it looks like the imx219 driver got loaded instead of the Jetvariety/OV2311 driver. Anyone seen this before?
Hey, thanks for the detailed writeup. That’s helpful. The install finishing cleanly but the wrong driver being active usually points to the device tree or the extlinux.conf entry not actually taking effect after reboot, not to the install script itself.
Can you paste the output of:
lsmod | grep -E ‘imx219|arducam’
cat /proc/device-tree/model
grep -A6 JetsonIO /boot/extlinux/extlinux.conf
Also, which entry is currently the default in extlinux.conf? If the JNX30M uses custom firmware, the bootloader may be picking a different LABEL than the one the Arducam installer added.
Sure, here’s what I get. The camera-specific block it added looks like this:
LABEL JetsonIO
MENU LABEL Custom Header Config:
LINUX /boot/arducam/Image
FDT /boot/arducam/dts/tegra194-p3668-all-p3509-0000-user-custom.dtb
INITRD /boot/initrd
APPEND ${cbootargs} quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 nv-auto-config
And dmesg | grep imx219 gives driver lines, while dmesg | grep arducam gives nothing. So imx219 is definitely the one loaded.
OK, that FDT line is the key thing to look at. The Arducam installer writes a specific dtb path into extlinux.conf, and if that FDT doesn’t match your actual board + JetPack combo, the kernel boots with the wrong device tree and the camera driver never binds.
A couple of things to check:
  1. Confirm the dtb file actually exists: ls -l /boot/arducam/dts/tegra194-p3668-all-p3509-0000-user-custom.dtb
  2. Check which LABEL is DEFAULT in extlinux.conf, and whether the bootloader is actually honoring it on your carrier board.
Also, can you confirm this install was done on a clean JetPack 4.6.2, or did you upgrade from something else?
The dtb file exists, I checked that. The JetsonIO label was added and I set it as default. But rebooting still gives me imx219 in dmesg and nothing for arducam.
One more thing I should mention: on an older JetPack 4.5.1 the driver seemed to load fine. That’s what made me think the carrier board and the NX module itself aren’t faulty. And to double check the board, I connected an IMX219 camera and it worked fine and captured images on this same JetPack 4.6.2 system. So the board does seem to work as expected.
That’s actually really good info, and it narrows things down a lot.
So to recap what we know:
  • JetPack 4.5.1: Jetvariety/OV2311 driver appears to load
  • JetPack 4.6.2 + IMX219: works, can capture images
  • JetPack 4.6.2 + OV2311 + Arducam dual dtb: boots with imx219 driver, no arducam entries in dmesg
That pattern suggests the problem isn’t the camera being dead and isn’t the carrier board being dead in general. It points more at a mismatch between the Arducam device tree/boot image and the specific JetPack 4.6.2 kernel on your setup.
A few more diagnostics to confirm before I say anything definite:
uname -a
ls /boot/arducam/
ls /boot/arducam/dts/
cat /proc/device-tree/compatible
Also check if there are any boot errors: dmesg | grep -iE ‘dtb|device tree|tegra194’
Here you go:
uname -a → Linux … 4.9.253-tegra #1 SMP PREEMPT … aarch64 GNU/Linux
The /boot/arducam/ and /boot/arducam/dts/ folders both look populated and the user-custom dtb is present. I don’t see obvious device tree errors in dmesg, nothing that stands out with grep for dtb/tegra194.
So it really does look like the wrong driver just keeps getting loaded no matter what I do with extlinux.conf. Is this something that’s been seen before? If there’s a known fix I’d love to hear it, otherwise any advice on what else to try would help.
Thanks, that lines up with what I suspected. Based on everything you’ve described, you’re running on a third-party development board (the JNX30M with vendor-custom firmware) rather than an official NVIDIA devkit. That matters a lot here, because some of our cameras have known compatibility issues on third-party carrier boards, and the device tree/boot image we ship is built against the official platform.
Because a third-party carrier board is in the picture, I honestly can’t confirm from here whether the issue is with the camera itself or with the hardware platform. The 4.5.1 vs 4.6.2 difference and the fact that the IMX219 works are useful data points, but they don’t let us rule out a firmware/device-tree interaction on that specific board.
That makes sense, I was afraid it might come down to the carrier board. So what’s the most reliable way to figure out whether the OV2311 itself is fine?
The cleanest way to isolate it is to test the camera on an official development kit. That removes the third-party carrier board and its custom firmware from the equation entirely.
So the plan I’d suggest:
  1. Put the OV2311 on the official devkit with the matching JetPack version.
  2. Run the same install_full.sh and confirm with dmesg | grep arducam that the driver binds this time.
  3. If it works there, the camera is fine and the issue is the third-party platform.
If the cameras still don’t work on the official development kit, come back to us and we’ll dig in further, because at that point the camera itself would be the prime suspect.
Alright, that gives me a clear path. I’ll try to get access to an official devkit and test the OV2311 there, then report back what dmesg shows. Thanks for the help.
Sounds good. Just to sum up where we landed:
  • The symptom is that on JetPack 4.6.2 the imx219 driver loads and dmesg | grep arducam returns nothing, even after install_full.sh completes without errors.
  • The hardware is a Jetson Xavier NX on a third-party JNX30M carrier board with vendor custom firmware, so the Arducam device tree/boot image doesn’t necessarily match what that platform actually boots into.
  • The likely cause is an incompatibility between that third-party board/firmware and the camera, not a confirmed fault in the camera.
  • The next step is to test the OV2311 on an official development kit to confirm the camera works properly.
If it still doesn’t work on the official devkit, reach out again and we’ll keep troubleshooting from there.
