Hi everyone, I’m trying to get an Arducam OG02B10 camera working on my Raspberry Pi, but it’s not being detected at all. When I check the camera status I just get a probe error. My kernel headers are 6.1.0-rpi6-rpi-v8, but the user guide only lists versions up to 5.1.0 (https://www.uctronics.com/download/Amazon/B0348_Manual.pdf). Does anyone know how to work with this older kernel header version? I’m a bit stuck here.
Thanks for the details. Before we go down the kernel version rabbit hole, let’s rule out the basics first. Can you post a couple of photos of the physical connection, both the camera end and the Raspberry Pi end? A camera that isn’t detected is often a ribbon cable or wiring issue. It would also help if you generate a bug report so we can see the full picture of what the system reports.
Here’s how to generate the Arducam bug report:
- Reboot the Pi.
- Download the tool with:
wget -O arducam-camera-bug-report https://github.com/ketai-dhr/arducam-camera-bug-report/releases/download/tools/arducam-camera-bug-report - Make it executable:
chmod +x ./arducam-camera-bug-report - Run it:
It will create an arducam-bug-report.txt file in the current directory. You can attach that file in a private message and I’ll take a look at what it collects.
Quick update, I found the problem before I even got to the bug report. The camera ribbon cable was only loosely seated. After I reseated it properly, video recording and image capture both work now. Thanks for pointing me toward the hardware side.
Glad to hear it. Loose connections are a really common cause of that probe error, so that fits with what you were seeing.
New issue though. I installed gstreamer and tried recording with gst-launch-1.0, but it fails with ‘No element libcamerasrc’. I also installed libcamera_dev and I can see the Arducam properties, but the Pi still can’t find libcamerasrc. I even tried the steps from this Stack Overflow thread (https://stackoverflow.com/questions/77964020/gstreamer-and-libcamera-warning-erroneous-pipeline-no-element-libcamerasrc) but no luck. How do I install libcamerasrc?
The gstreamer/libcamerasrc route tends to be painful on the Pi. Rather than fighting with the missing element, try libcamera-vid instead, it’s simpler and works reliably for recording. For example:
libcamera-vid -t 20000 -o test.h264
That records 20 seconds to test.h264.
Okay, I’ll go with libcamera-vid for recording instead of gst-launch-1.0/libcamerasrc. That’s much easier than trying to get libcamerasrc installed.
One more thing I’m trying to sort out. I want to trigger the OG02B10 externally and wire it together with an optical infrared sensor on the Raspberry Pi. I found a setup video (https://youtu.be/f_saNQQACOo?si=EmN5z1k4bVoPF_N5) but it doesn’t show any wiring details. Is there a user guide for external triggering?
The official Arducam docs cover external triggering for the Global Shutter Camera, including the wiring details. Check the introduction section here:
https://docs.arducam.com/Raspberry-Pi-Camera/Global-Shutter-Camera/external-trigger/#introduction
Perfect, I’ll go through that. Thanks for the help!
