I’m using an arducam multi camera adapter v2.2. For the moment, I’ve two camera connected. Before I start the camera, I write these commands:
sudo apt-get install python3-pyqt5
sudo apt-get install python3-opencv
sudo apt-get upgrade
sudo apt install -y python3-kms++ python3-libcamera
sudo apt install -y python3-pyqt5 python3-prctl libatlas-base-dev ffmpeg
sudo pip3 install numpy --upgrade
sudo pip3 install picamera2
cd /tmp
wget https://project-downloads.drogon.net/wiringpi-latest.deb
sudo dpkg -i wiringpi-latest.deb
Then I update the kernel:
sudo rpi-update
And modify:
/boot/config.txt
# http://rpf.io/configtxt
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
dtparam=i2c_arm=on
dtparam=i2c_vc=on
dtparam=i2s=on
dtparam=spi=on
dtparam=audio=on
camera_auto_detect=0
dtoverlay=camera-mux-4port,cam0-imx477,cam1-imx477
display_auto_detect=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
disable_overscan=1
[cm4]
otg_mode=1
[pi4]
arm_boost=1
When I try to execute
init_camera.sh
----Test i2c1
00: -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- 1a -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- 64 -- -- -- -- -- -- -- -- -- -- --
70: 70 -- -- -- -- -- -- --
----Detecting the /dev/video0 device
Can't find video0 device, please check the hardware connection!```
And If i do
libcamera-hello --camera 0
Made X/EGL preview window
[0:05:10.697059953] [1406] INFO Camera camera_manager.cpp:293 libcamera v0.0.1+21-7c855784
[0:05:10.714676058] [1419] ERROR RPI raspberrypi.cpp:1223 Failed to register camera imx477 23-001a: -2
ERROR: *** no cameras available ***```
The hardware connection is correct. Should I modify something in the config.txt file? My kernel version is:
Linux raspberrypi 5.15.74-v7l+ #1595 SMP Wed Oct 26 11:05:08 BST 2022 armv7l GNU/Linux
Side Note: I think this is important:
