I’m stuck trying to get an Arducam MultiCamera Adapter v2.2 working on my Raspberry Pi. Honestly it feels like my system just isn’t compatible with the adapter and I’m not sure what I’m doing wrong.
When I run sudo ./init_camera.sh all four cameras (A, B, C, D) fail. Here’s the full output:
pi@raspberrypi:~/RaspberryPi/Multi_Camera_Adapter/Multi_Adapter_Board_4Channel/Multi_Camera_Adapter_V2.2_python $ sudo ./init_camera.sh
----Test i2c1
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- 36 -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: 70 -- -- -- -- -- -- --
----Detecting the /dev/video0 device
video0 detected!
--Start testing each camera
if all of them are normal, after it finished,you will see four image in the current path.
Start testing the camera A
ERROR: the system appears to be configured for the legacy camera stack
Start testing the camera B
Start testing the camera C
Start testing the camera D
The weird part is the cameras were actually detected (it literally says “video0 detected!”), and i2c shows something at 0x36 and 0x70, but every single camera test fails with that legacy camera stack error. Any idea what’s going on? Should I change the OS?
Hi, Bin from Arducam support here — thanks for the really detailed report, that output helps a lot.
That line, ERROR: the system appears to be configured for the legacy camera stack, is the key clue. It shows up when the Pi’s camera stack config doesn’t match what the adapter script expects.
The good news from your log is that the hardware side actually looks fine: i2c1 shows the adapter at 0x36 and 0x70, and /dev/video0 is detected, so the board is talking and wired up correctly.
Can you check a few things for me?
In raspi-config → Interface Options → Legacy Camera, is it currently enabled or disabled?
What do these lines look like in /boot/config.txt: start_x, gpu_mem, camera_auto_detect (and any dtoverlay lines)?
/boot/config.txt: start_x=1, gpu_mem=128, no camera_auto_detect line, and no dtoverlay lines for the adapter
ls /dev/video* → /dev/video0
vcgencmd get_camera → supported=1 detected=1
So the camera is being detected but init_camera.sh still throws the legacy camera stack error for all four cameras. Does the Legacy Camera setting have anything to do with it?
Yeah, that setting is very likely the culprit. With Legacy Camera ENABLED, the Pi runs the old MMAL-based camera stack, while the v2.2 script expects the newer libcamera-based stack. That mismatch is exactly what the “legacy camera stack” message is complaining about — which is also why i2c and /dev/video0 detection still succeed, since it’s the capture side that’s rejecting it.
A couple of things to try while we dig further:
Turn Legacy Camera OFF in raspi-config, then reboot.
Make sure the OS is fully up to date first: sudo apt update && sudo apt full-upgrade, then reboot.
Re-run sudo ./init_camera.sh from your Multi_Camera_Adapter_V2.2_python directory.
Post the output after that and we’ll see where we stand.
OK, I turned Legacy Camera off, rebooted, updated everything, and re-ran sudo ./init_camera.sh. Same result unfortunately:
----Test i2c1
video0 detected!
i2c still detects 0x36 and 0x70, and video0 is still detected, but every camera test fails with the same error. At this point I’m wondering if I should just change the OS entirely — is Buster Legacy the wrong choice for this adapter?
Quick follow-up since I’m at a bit of a dead end: is switching to a different OS the recommended path here, or is there a config step I’m missing on Buster Legacy? I’ve tried toggling Legacy Camera and updating, but the legacy camera stack error persists for cameras A/B/C/D even though the adapter (0x36, 0x70) and video0 are both detected.
Thanks for testing all that — it matches what we’re seeing on our side, so you’re not doing anything wrong.
To summarize where we are: the i2c side is perfect (0x36 + 0x70), /dev/video0 is present, but every capture test bails out with the “the system appears to be configured for the legacy camera stack” message. That points to an OS / camera-stack configuration issue rather than anything wrong with the adapter hardware itself.
One thing on our end: the RPi’s system has now been updated, and we’re going to test this tomorrow to nail down the exact steps. I’ll reply as soon as I have something concrete — I don’t want to hand you a half-guess fix right now.
My suggestion would be to hold off on wiping your install just yet until we’ve confirmed the correct configuration. In the meantime, I’ve sent you a couple of diagnostic tools through private message so we can capture more detail from your setup — please check your inbox and we’ll continue from there.
