Arducam Multi Camera Board V2.2 no Camera available
    Amazon, they are Arducam boxed hardware. Have two cameras in testing, OV5647 5MP camera and imx219 8mp camera.
    OV5647 5MP
    imx219 8mp
    B012001 - 4 port
    rpi 5
    Quick Start Guide for Multi-Camera Adapter Board - Arducam Wiki
  5. Problems you were having?
    After setting auto detect to 0 and adding dtoverlay as instructed in the ADD section of config.txt, fails to find any cameras. If i leave auto detect on and set the camera to port1, i am able to auto connect for ~15 seconds and the camera is on and working. Properly identifies as ov5647 when auto detecting.
    Have attempted to change different cable and port connections. Confirmed that Camera is working if ribbon goes directly to board. Since the camera is able to auto detect I believe this proves all connections testing good since it can actually pull raw from the camera momentarily.
  8. What help do you need?
    Need to determine while when i turn off Auto Connect and use
    dtoverlay=camera-mux-4port,cam1-ov5647
    No camera is detected.
  9. Attached are further logs and information that was requested in submitting a case
admin@pi:~ $ uname -a
Linux pi 6.12.109+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.12.109-1+rpt1 (2026-09-11) aarch64 GNU/Linux
admin@pi:~ $ cat /etc/os-release
PRETTY_NAME=“Debian GNU/Linux 12 (bookworm)”
NAME=“Debian GNU/Linux”
VERSION_ID=“12”
VERSION=“12 (bookworm)”
VERSION_CODENAME=bookworm
ID=debian
HOME_URL=“https ://www.debian.org/”
SUPPORT_URL=“https ://www.debian.org/support”
BUG_REPORT_URL=“https ://bugs.debian.org/”
admin@pi:~ $ cat /proc/meminfo
MemTotal: 8252416 kB
MemFree: 7089616 kB
MemAvailable: 7679008 kB
Buffers: 36016 kB
Cached: 631632 kB
SwapCached: 0 kB
Active: 600784 kB
Inactive: 360832 kB
Active(anon): 324240 kB
Inactive(anon): 0 kB
Active(file): 276544 kB
Inactive(file): 360832 kB
Unevictable: 12016 kB
Mlocked: 0 kB
SwapTotal: 204784 kB
SwapFree: 204784 kB
Zswap: 0 kB
Zswapped: 0 kB
Dirty: 48 kB
Writeback: 0 kB
AnonPages: 305984 kB
Mapped: 177712 kB
Shmem: 30272 kB
KReclaimable: 26672 kB
Slab: 71936 kB
SReclaimable: 26672 kB
SUnreclaim: 45264 kB
KernelStack: 5568 kB
PageTables: 12256 kB
SecPageTables: 144 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 4330992 kB
Committed_AS: 1686256 kB
VmallocTotal: 68447887360 kB
VmallocUsed: 51488 kB
VmallocChunk: 0 kB
Percpu: 1344 kB
CmaTotal: 65536 kB
CmaFree: 55296 kB
admin@pi:~ $ cat /boot/config.txt
DO NOT EDIT THIS FILE
The file you are looking for has moved to /boot/firmware/config.txt
admin@pi:~ $ cat /boot/firmware/config.txt
http://rptl.io/configtxt
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
Additional overlays and parameters are documented
/boot/firmware/overlays/README
camera_auto_detect=1
dtoverlay=arducam
display_auto_detect=0
Automatically load initramfs files, if found
auto_initramfs=1
Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
Don’t have the firmware create an initial video= setting in cmdline.txt.
Use the kernel’s default instead.
disable_fw_kms_setup=1
Run in 64-bit mode
arm_64bit=1
disable_overscan=1
arm_boost=1
[cm4]
otg_mode=1
[cm5]
dtoverlay=dwc2,dr_mode=host
[pi5]
dtoverlay=nospi10
#dtoverlay=camera-mux-4port,cam1-ov5647
admin@pi:~ $ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x414fd0b1]
[ 0.000000] Linux version 6.12.109+rpt-rpi-2712 ([email protected]) (aarch64-linux-gnu-gcc-12 (Debian 12.2.0-14+deb12u1) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT Debian 1:6.12.109-1+rpt1 (2026-09-11)
[ 0.000000] KASLR enabled
[ 0.000000] Machine model: Raspberry Pi 5 Model B Rev 1.1
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000003a000000, size 64 MiB
[ 0.000000] OF: reserved mem: 0x000000003a000000…0x000000003dffffff (65536 KiB) map reusable linux,cma
[ 0.000000] OF: reserved mem: 0x0000000000000000…0x000000000007ffff (512 KiB) nomap non-reusable atf@0
[ 0.000000] OF: reserved mem: 0x000000003fd23600…0x000000003fd2363d (0 KiB) nomap non-reusable nvram@0
[ 0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000001ffffffff]
[ 0.000000] Faking node 0 at [mem 0x0000000000000000-0x000000003fffffff] (1024MB)
[ 0.000000] Faking node 1 at [mem 0x0000000040000000-0x000000007fffffff] (1024MB)
[ 0.000000] Faking node 2 at [mem 0x0000000080000000-0x00000000bfffffff] (1024MB)
[ 0.000000] Faking node 3 at [mem 0x00000000c0000000-0x00000000ffffffff] (1024MB)
[ 0.000000] Faking node 4 at [mem 0x0000000100000000-0x000000013fffffff] (1024MB)
[ 0.000000] Faking node 5 at [mem 0x0000000140000000-0x000000017fffffff] (1024MB)
[ 0.000000] Faking node 6 at [mem 0x0000000180000000-0x00000001bfffffff] (1024MB)
[ 0.000000] Faking node 7 at [mem 0x00000001c0000000-0x00000001ffffffff] (1024MB)
[ 0.000000] NUMA: Initialized distance table, cnt=8
[ 0.000000] NODE_DATA(0) allocated [mem 0x3f7fd200-0x3f7fffff]
[ 0.000000] NODE_DATA(1) allocated [mem 0x7fffd200-0x7fffffff]
[ 0.000000] NODE_DATA(2) allocated [mem 0xbfffd200-0xbfffffff]
[ 0.000000] NODE_DATA(3) allocated [mem 0xffffd200-0xffffffff]
[ 0.000000] NODE_DATA(4) allocated [mem 0x13fffd200-0x13fffffff]
[ 0.000000] NODE_DATA(5) allocated [mem 0x17fffd200-0x17fffffff]
[ 0.000000] NODE_DATA(6) allocated [mem 0x1bfffd200-0x1bfffffff]
[ 0.000000] NODE_DATA(7) allocated [mem 0x1ffb99200-0x1ffb9bfff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x00000001ffffffff]
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000000007ffff]
[ 0.000000] node 0: [mem 0x0000000000080000-0x000000003f7fffff]
[ 0.000000] node 1: [mem 0x0000000040000000-0x000000007fffffff]
[ 0.000000] node 2: [mem 0x0000000080000000-0x00000000bfffffff]
[ 0.000000] node 3: [mem 0x00000000c0000000-0x00000000ffffffff]
[ 0.000000] node 4: [mem 0x0000000100000000-0x000000013fffffff]
[ 0.000000] node 5: [mem 0x0000000140000000-0x000000017fffffff]
[ 0.000000] node 6: [mem 0x0000000180000000-0x00000001bfffffff]
[ 0.000000] node 7: [mem 0x00000001c0000000-0x00000001ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000003f7fffff]
[ 0.000000] Initmem setup node 1 [mem 0x0000000040000000-0x000000007fffffff]
[ 0.000000] Initmem setup node 2 [mem 0x0000000080000000-0x00000000bfffffff]
[ 0.000000] Initmem setup node 3 [mem 0x00000000c0000000-0x00000000ffffffff]
[ 0.000000] Initmem setup node 4 [mem 0x0000000100000000-0x000000013fffffff]
[ 0.000000] Initmem setup node 5 [mem 0x0000000140000000-0x000000017fffffff]
[ 0.000000] Initmem setup node 6 [mem 0x0000000180000000-0x00000001bfffffff]
[ 0.000000] Initmem setup node 7 [mem 0x00000001c0000000-0x00000001ffffffff]
[ 0.000000] On node 1, zone DMA: 512 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 15 pages/cpu s193944 r8192 d43624 u245760
[ 0.000000] pcpu-alloc: s193944 r8192 d43624 u245760 alloc=15*16384
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: detected: Broken broadcast TLBI completion
[ 0.000000] CPU features: detected: SSBS not fully self-synchronizing
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 numa=fake=8 system_heap.max_order=0 iommu_dma_numa_policy=interleave smsc95xx.macaddr=98:FE:54:1C:9A:03 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 console=ttyAMA10,115200 console=tty1 root=PARTUUID=70352884-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=US
[ 0.000000] cgroup: Disabling memory control group subsystem
[ 0.000000] mempolicy: NUMA default policy overridden to ‘interleave:0-7’
[ 0.000000] DMA IOMMU NUMA default policy overridden to ‘interleave:0-7’
[ 0.000000] Fallback order for Node 0: 0 1 2 3 4 5 6 7
[ 0.000000] Fallback order for Node 1: 1 2 3 4 5 6 7 0
[ 0.000000] Fallback order for Node 2: 2 3 4 5 6 7 0 1
[ 0.000000] Fallback order for Node 3: 3 4 5 6 7 0 1 2
[ 0.000000] Fallback order for Node 4: 4 5 6 7 0 1 2 3
[ 0.000000] Fallback order for Node 5: 5 6 7 0 1 2 3 4
[ 0.000000] Fallback order for Node 6: 6 7 0 1 2 3 4 5
[ 0.000000] Fallback order for Node 7: 7 0 1 2 3 4 5 6
[ 0.000000] Built 8 zonelists, mobility grouping on. Total pages: 523776
[ 0.000000] Policy zone: Normal
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbffc000-0x00000000ffffc000] (64MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=8
[ 0.000000] ftrace: allocating 45057 entries in 45 pages
[ 0.000000] ftrace: allocated 45 pages with 4 groups
[ 0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[ 0.000000] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[ 0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.000000] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000094] Console: colour dummy device 80x25
[ 0.000099] printk: legacy console [tty1] enabled
[ 0.000170] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=216000)
[ 0.000174] pid_max: default: 32768 minimum: 301
[ 0.000265] LSM: initializing lsm=capability
[ 0.001715] Dentry cache hash table entries: 1048576 (order: 9, 8388608 bytes, vmalloc)
[ 0.002421] Inode-cache hash table entries: 524288 (order: 8, 4194304 bytes, vmalloc)
[ 0.002467] Mount-cache hash table entries: 16384 (order: 3, 131072 bytes, vmalloc)
[ 0.002487] Mountpoint-cache hash table entries: 16384 (order: 3, 131072 bytes, vmalloc)
[ 0.003197] rcu: Hierarchical SRCU implementation.
[ 0.003202] rcu: Max phase no-delay instances is 1000.
[ 0.003243] Timer migration: 1 hierarchy levels; 8 children per group; 0 crossnode level
[ 0.003593] EFI services will not be available.
[ 0.003668] smp: Bringing up secondary CPUs …
[ 0.003838] Detected PIPT I-cache on CPU1
[ 0.003874] CPU1: Booted secondary processor 0x0000000100 [0x414fd0b1]
[ 0.004111] Detected PIPT I-cache on CPU2
[ 0.004140] CPU2: Booted secondary processor 0x0000000200 [0x414fd0b1]
[ 0.004311] Detected PIPT I-cache on CPU3
[ 0.004332] CPU3: Booted secondary processor 0x0000000300 [0x414fd0b1]
[ 0.004361] smp: Brought up 8 nodes, 4 CPUs
[ 0.004366] SMP: Total of 4 processors activated.
[ 0.004367] CPU: All CPU(s) started at EL2
[ 0.004370] CPU features: detected: 32-bit EL0 Support
[ 0.004371] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.004373] CPU features: detected: Common not Private translations
[ 0.004374] CPU features: detected: CRC32 instructions
[ 0.004377] CPU features: detected: RCpc load-acquire (LDAPR)
[ 0.004378] CPU features: detected: LSE atomic instructions
[ 0.004379] CPU features: detected: Privileged Access Never
[ 0.004380] CPU features: detected: RAS Extension Support
[ 0.004382] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.004407] alternatives: applying system-wide alternatives
[ 0.005842] CPU features: detected: Hardware dirty bit management on CPU0-3
[ 0.006036] Memory: 8133392K/8380416K available (14272K kernel code, 2416K rwdata, 4960K rodata, 5696K init, 644K bss, 151360K reserved, 65536K cma-reserved)
[ 0.006202] devtmpfs: initialized
[ 0.008100] Enabled cp15_barrier support
[ 0.008105] Enabled setend support
[ 0.008146] futex hash table entries: 1024 (order: 2, 65536 bytes, vmalloc)
[ 0.008254] 2G module region forced by RANDOMIZE_MODULE_REGION_FULL
[ 0.008255] 0 pages in range for non-PLT usage
[ 0.008256] 129300 pages in range for PLT usage
[ 0.008335] pinctrl core: initialized pinctrl subsystem
[ 0.008463] DMI not present or invalid.
[ 0.011439] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.011755] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.011784] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.011812] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.011825] audit: initializing netlink subsys (disabled)
[ 0.011866] audit: type=2000 audit(0.008:1): state=initialized audit_enabled=0 res=1
[ 0.011960] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.011969] cpuidle: using governor menu
[ 0.012029] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.012049] ASID allocator initialised with 32768 entries
[ 0.012272] Serial: AMBA PL011 UART driver
[ 0.013006] /soc@107c000000/interrupt-controller@7fff9000: Fixed dependency cycle(s) with /soc@107c000000/interrupt-controller@7fff9000
[ 0.013159] bcm2835-mbox 107c013880.mailbox: mailbox enabled
[ 0.013284] 107d001000.serial: ttyAMA10 at MMIO 0x107d001000 (irq = 15, base_baud = 0) is a PL011 rev3
[ 0.013293] printk: legacy console [ttyAMA10] enabled
[ 0.020014] raspberrypi-firmware soc@107c000000:firmware: Attached to firmware from 2026-05-11T11:20:02, variant start_cd
[ 0.024014] raspberrypi-firmware soc@107c000000:firmware: Firmware hash is 66f33f7e00000000000000000000000000000000
[ 0.029013] /axi/pcie@1000120000/rp1/i2c@88000/ov5647@36: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@110000
[ 0.029041] /axi/pcie@1000120000/rp1/csi@110000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@88000/ov5647@36
[ 0.029161] /axi/pcie@1000120000/rp1/i2c@88000/ov5647@36: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@110000
[ 0.029189] /axi/pcie@1000120000/rp1/csi@110000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@88000/ov5647@36
[ 0.036432] bcm2835-dma 1000010000.dma: DMA legacy API manager, dmachans=0x1
[ 0.036685] iommu: Default domain type: Translated
[ 0.036688] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.036972] SCSI subsystem initialized
[ 0.037002] usbcore: registered new interface driver usbfs
[ 0.037009] usbcore: registered new interface driver hub
[ 0.037014] usbcore: registered new device driver usb
[ 0.037082] pps_core: LinuxPPS API ver. 1 registered
[ 0.037083] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [email protected]
[ 0.037086] PTP clock support registered
[ 0.037357] vgaarb: loaded
[ 0.037434] clocksource: Switched to clocksource arch_sys_counter
[ 0.237532] VFS: Disk quotas dquot_6.6.0
[ 0.237542] VFS: Dquot-cache hash table entries: 2048 (order 0, 16384 bytes)
[ 0.239089] NET: Registered PF_INET protocol family
[ 0.239265] IP idents hash table entries: 131072 (order: 6, 1048576 bytes, vmalloc)
[ 0.240823] tcp_listen_portaddr_hash hash table entries: 4096 (order: 2, 65536 bytes, vmalloc)
[ 0.240849] Table-perturb hash table entries: 65536 (order: 4, 262144 bytes, vmalloc)
[ 0.240856] TCP established hash table entries: 65536 (order: 5, 524288 bytes, vmalloc)
[ 0.241053] TCP bind hash table entries: 65536 (order: 7, 2097152 bytes, vmalloc)
[ 0.241732] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.241841] MPTCP token hash table entries: 8192 (order: 4, 196608 bytes, vmalloc)
[ 0.241884] UDP hash table entries: 4096 (order: 3, 131072 bytes, vmalloc)
[ 0.241949] UDP-Lite hash table entries: 4096 (order: 3, 131072 bytes, vmalloc)
[ 0.242048] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.242178] RPC: Registered named UNIX socket transport module.
[ 0.242180] RPC: Registered udp transport module.
[ 0.242181] RPC: Registered tcp transport module.
[ 0.242182] RPC: Registered tcp-with-tls transport module.
[ 0.242183] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.242188] PCI: CLS 0 bytes, default 64
[ 0.242286] Trying to unpack rootfs image as initramfs…
[ 0.246435] kvm [1]: nv: 554 coarse grained trap handlers
[ 0.246526] kvm [1]: IPA Size Limit: 40 bits
[ 0.246536] kvm [1]: GICV region size/alignment is unsafe, using trapping (reduced performance)
[ 0.246560] kvm [1]: vgic interrupt IRQ9
[ 0.246571] kvm [1]: VHE mode initialized successfully
[ 0.246958] Initialise system trusted keyrings
[ 0.247127] workingset: timestamp_bits=42 max_order=19 bucket_order=0
[ 0.247391] NFS: Registering the id_resolver key type
[ 0.247397] Key type id_resolver registered
[ 0.247399] Key type id_legacy registered
[ 0.247407] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.247410] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 0.247562] Key type asymmetric registered
[ 0.247564] Asymmetric key parser ‘x509’ registered
[ 0.247583] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.247613] io scheduler mq-deadline registered
[ 0.247615] io scheduler kyber registered
[ 0.247628] io scheduler bfq registered
[ 0.247914] irq_brcmstb_l2: registered L2 intc (/soc@107c000000/interrupt-controller@7d510600, parent irq: 26)
[ 0.247946] irq_brcmstb_l2: registered L2 intc (/soc@107c000000/interrupt-controller@7c502000, parent irq: 27)
[ 0.247973] irq_brcmstb_l2: registered L2 intc (/soc@107c000000/intc@7d508380, parent irq: 28)
[ 0.247996] irq_brcmstb_l2: registered L2 intc (/soc@107c000000/intc@7d508400, parent irq: 29)
[ 0.248025] irq_brcmstb_l2: registered L2 intc (/soc@107c000000/intc@7d503000, parent irq: 30)
[ 0.253473] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.400774] Freeing initrd memory: 17664K
[ 0.401537] simple-framebuffer 3f800000.framebuffer: framebuffer at 0x3f800000, 0x3f4800 bytes
[ 0.401543] simple-framebuffer 3f800000.framebuffer: format=r5g6b5, mode=1920x1080x16, linelength=3840
[ 0.401724] Console: switching to colour frame buffer device 240x67
[ 0.403014] simple-framebuffer 3f800000.framebuffer: fb0: simplefb registered!
[ 0.432483] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 0.432770] 107d50c000.serial: ttyS0 at MMIO 0x107d50c000 (irq = 32, base_baud = 6000000) is a Broadcom BCM7271 UART
[ 0.432807] serial serial0: tty port ttyS0 registered
[ 0.433050] iproc-rng200 107d208000.rng: hwrng registered
[ 0.433082] vc-mem: phys_addr:0x00000000 mem_base=0x3fc00000 mem_size:0x40000000(1024 MiB)
[ 0.433261] bcm2712-iommu-cache 1000005b00.iommuc: bcm2712_iommu_cache_probe
[ 0.434523] brd: module loaded
[ 0.435369] loop: module loaded
[ 0.435459] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 0.435556] Loading iSCSI transport class v2.0-870.
[ 0.436222] usbcore: registered new interface driver lan78xx
[ 0.436231] usbcore: registered new interface driver smsc95xx
[ 0.436277] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.436292] dwc_otg: FIQ enabled
[ 0.436293] dwc_otg: NAK holdoff enabled
[ 0.436294] dwc_otg: FIQ split-transaction FSM enabled
[ 0.436296] Module dwc_common_port init
[ 0.436487] usbcore: registered new interface driver uas
[ 0.436495] usbcore: registered new interface driver usb-storage
[ 0.436559] mousedev: PS/2 mouse device common for all mice
[ 0.444060] rpi-rtc soc@107c000000:rpi_rtc: registered as rtc0
[ 0.445442] rpi-rtc soc@107c000000:rpi_rtc: setting system clock to 2026-09-21T01:19:23 UTC (1789953563)
[ 0.445726] bcm2835-wdt bcm2835-wdt: Poweroff handler already present!
[ 0.445728] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 0.447719] sdhci: Secure Digital Host Controller Interface driver
[ 0.447721] sdhci: Copyright(c) Pierre Ossman
[ 0.447749] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.447831] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping …
[ 0.447840] hid: raw HID events driver (C) Jiri Kosina
[ 0.447858] usbcore: registered new interface driver usbhid
[ 0.447859] usbhid: USB HID core driver
[ 0.448117] hw perfevents: enabled with armv8_cortex_a76 PMU driver, 7 (0,8000003f) counters available
[ 0.448332] NET: Registered PF_PACKET protocol family
[ 0.448353] Key type dns_resolver registered
[ 0.451784] registered taskstats version 1
[ 0.451843] Loading compiled-in X.509 certificates
[ 0.453252] Demotion targets for Node 0: null
[ 0.453254] Demotion targets for Node 1: null
[ 0.453255] Demotion targets for Node 2: null
[ 0.453256] Demotion targets for Node 3: null
[ 0.453257] Demotion targets for Node 4: null
[ 0.453258] Demotion targets for Node 5: null
[ 0.453259] Demotion targets for Node 6: null
[ 0.453260] Demotion targets for Node 7: null
[ 0.453402] Key type .fscrypt registered
[ 0.453404] Key type fscrypt-provisioning registered
[ 0.454100] brcm-pcie 1000120000.pcie: host bridge /axi/pcie@1000120000 ranges:
[ 0.454105] brcm-pcie 1000120000.pcie: No bus range found for /axi/pcie@1000120000, using [bus 00-ff]
[ 0.454113] brcm-pcie 1000120000.pcie: MEM 0x1f00000000…0x1ffffffffb → 0x0000000000
[ 0.454117] brcm-pcie 1000120000.pcie: MEM 0x1c00000000…0x1effffffff → 0x0400000000
[ 0.454122] brcm-pcie 1000120000.pcie: IB MEM 0x1f00000000…0x1f003fffff → 0x0000000000
[ 0.454127] brcm-pcie 1000120000.pcie: IB MEM 0x0000000000…0x0fffffffff → 0x1000000000
[ 0.454130] brcm-pcie 1000120000.pcie: IB MEM 0x1000130000…0x1000130fff → 0xfffffff000
[ 0.455470] brcm-pcie 1000120000.pcie: PCI host bridge to bus 0002:00
[ 0.455474] pci_bus 0002:00: root bus resource [bus 00-ff]
[ 0.455477] pci_bus 0002:00: root bus resource [mem 0x1f00000000-0x1ffffffffb] (bus address [0x00000000-0xfffffffb])
[ 0.455479] pci_bus 0002:00: root bus resource [mem 0x1c00000000-0x1effffffff pref] (bus address [0x400000000-0x6ffffffff])
[ 0.455492] pci 0002:00:00.0: [14e4:2712] type 01 class 0x060400 PCIe Root Port
[ 0.455497] pci 0002:00:00.0: PCI bridge to [bus 00]
[ 0.455500] pci 0002:00:00.0: bridge window [mem 0x1f80000000-0x1fbfffffff]
[ 0.455516] pci 0002:00:00.0: PME# supported from D0 D3hot
[ 0.456108] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.557437] brcm-pcie 1000120000.pcie: clkreq-mode set to default
[ 0.557439] brcm-pcie 1000120000.pcie: link up, 5.0 GT/s PCIe x4 (!SSC)
[ 0.557462] pci 0002:01:00.0: [1de4:0001] type 00 class 0x020000 PCIe Endpoint
[ 0.557474] pci 0002:01:00.0: BAR 0 [mem 0xffffc000-0xffffffff]
[ 0.557481] pci 0002:01:00.0: BAR 1 [mem 0xffc00000-0xffffffff]
[ 0.557486] pci 0002:01:00.0: BAR 2 [mem 0xffff0000-0xffffffff]
[ 0.557551] pci 0002:01:00.0: supports D1
[ 0.557553] pci 0002:01:00.0: PME# supported from D0 D1 D3hot D3cold
[ 0.565443] pci_bus 0002:01: busn_res: [bus 01-ff] end is updated to 01
[ 0.565451] pci 0002:00:00.0: bridge window [mem 0x1f00000000-0x1f005fffff]: assigned
[ 0.565454] pci 0002:01:00.0: BAR 1 [mem 0x1f00000000-0x1f003fffff]: assigned
[ 0.565458] pci 0002:01:00.0: BAR 2 [mem 0x1f00400000-0x1f0040ffff]: assigned
[ 0.565461] pci 0002:01:00.0: BAR 0 [mem 0x1f00410000-0x1f00413fff]: assigned
[ 0.565465] pci 0002:00:00.0: PCI bridge to [bus 01]
[ 0.565467] pci 0002:00:00.0: bridge window [mem 0x1f00000000-0x1f005fffff]
[ 0.565470] pci_bus 0002:00: resource 4 [mem 0x1f00000000-0x1ffffffffb]
[ 0.565472] pci_bus 0002:00: resource 5 [mem 0x1c00000000-0x1effffffff pref]
[ 0.565474] pci_bus 0002:01: resource 1 [mem 0x1f00000000-0x1f005fffff]
[ 0.565477] pci 0002:00:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 0.565485] pci 0002:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 0.565548] pcieport 0002:00:00.0: enabling device (0000 → 0002)
[ 0.565574] pcieport 0002:00:00.0: PME: Signaling with IRQ 37
[ 0.565624] pcieport 0002:00:00.0: AER: enabled with IRQ 37
[ 0.565712] rp1 0002:01:00.0: bar0 len 0x4000, start 0x1f00410000, end 0x1f00413fff, flags, 0x40200
[ 0.565715] rp1 0002:01:00.0: bar1 len 0x400000, start 0x1f00000000, end 0x1f003fffff, flags, 0x40200
[ 0.565725] rp1 0002:01:00.0: enabling device (0000 → 0002)
[ 0.566337] rp1 0002:01:00.0: chip_id 0x20001927
[ 0.569998] /axi/pcie@1000120000/rp1/i2c@88000/ov5647@36: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@110000
[ 0.570309] /axi/pcie@1000120000/rp1/i2c@88000/ov5647@36: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@110000
[ 0.570323] /axi/pcie@1000120000/rp1/csi@110000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@88000/ov5647@36
[ 0.570754] bcm2712-iommu 1000005100.iommu: IOVA aperture 0xa00000000…0xb00000000 including DMA offset 0x0
[ 0.570772] bcm2712-iommu 1000005100.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[ 0.570825] bcm2712-iommu 1000005200.iommu: IOVA aperture 0xa00000000…0xa80000000 including DMA offset 0x0
[ 0.570842] bcm2712-iommu 1000005200.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[ 0.570886] bcm2712-iommu 1000005280.iommu: IOVA aperture 0x1a00000000…0x1a80000000 including DMA offset 0x1000000000
[ 0.570898] bcm2712-iommu 1000005280.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
Following up to see if there is any help on this. Currently stuck and unable to get multiple cameras running for my project.
