I go the IMX219-160s from [Waveshare]. I got the Arducam Multi Camera Adapter Module V2.2 from [UCTRONICS] -
B012001 (I think?) -
Jetson Nano, aarch64. JetPack 4.6.1-b110. -
Nvidia_Jetson/Multi_Camera_Adapter at master · ArduCAM/Nvidia_Jetson · GitHub -
Start testing the camera A
Error: Write failed
Encoder null, cannot set bitrate!
Encoder Profile = High
bitrate = 4000000
Encoder control-rate = 1
Encoder EnableTwopassCBR = 0
Opening in BLOCKING MODE
** Message: 13:26:51.825: <main:4674> iterating capture loop ....
Starting automation...
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:740 No cameras available
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
It then gets stuck here.
[Link to dmesg log](https://easyupload.io/e0qzrq).
Tried changing the Python code fromi2c = "i2cset -y 1 ...
to numbers other than 1, up until 8.
Changed the import fromRPi.GPIO as gp
toJetson.GPIO as GPIO
Get the MultiCamera Adapter to work because it was advertised to work with the Jetson Nano.
