Hey everyone, I’m trying to get an ArduCAM IMX708 MIPI camera working on my Jetson Xavier NX Developer Kit and hitting a wall during driver installation.
I ran the install script from the MIPI_Camera releases (v0.0.3):
This is a known situation — the v0.0.3 installer script doesn’t include a pre-built .deb package for your specific kernel version (5.10.216-tegra-35.6.2). The script checks its internal package list against your kernel and when there’s no match, it throws that error.
We have a troubleshooting page that covers exactly this scenario. Take a look here:
It walks through manual driver matching and some alternative approaches. Since the imx708_links.txt downloaded fine (11344 bytes), the script is pulling the package index correctly — it just doesn’t have a build for 5.10.216-tegra-35.6.2 in its release bundle.
Give that doc a read and let me know where you land.
Thanks for the pointer. I went through that troubleshooting page but I’m still stuck.
The issue seems to be a version mismatch. I dug into the available driver packages and it looks like IMX708 support tops out at JetPack 5.1.0 (the December 6th build). My system is on JetPack 5.1.5 with kernel 5.10.216-tegra-35.6.2, and there simply isn’t a .deb compiled for this combination.
Updated details:
JetPack: 5.1.5
Kernel: 5.10.216-tegra-35.6.2
Platform: NVIDIA Jetson Xavier NX Developer Kit
Camera: IMX708 (MIPI)
I tried manually looking through the release assets on GitHub too — no luck finding a driver that matches this kernel. Is there any way to get the IMX708 working on JetPack 5.1.5, or am I stuck until a newer driver package is released?
Unfortunately, ArduCAM does not currently support JetPack 5.1.5 / L4T 35.6.2 for the IMX708 driver. The available .deb packages for the IMX708 only go up to JetPack 5.1.0, and your kernel (5.10.216-tegra-35.6.2) falls outside that range.
The recommended path here is to flash your Jetson Xavier NX Developer Kit back to a supported JetPack version — specifically JetPack 5.1.2 — using NVIDIA SDK Manager:
SDK Manager will let you re-flash the device and select the target JetPack/L4T version during the setup process. Once you’re on JetPack 5.1.2, the v0.0.3 installer script should be able to find a matching .deb from its package list and complete the driver installation without issues.
I know a downgrade isn’t ideal, but it’s the cleanest path to getting the IMX708 up and running right now.
