Hi, I’ve been trying to get an ArduCAM Mega working with my Arduino Nano ESP32 but it doesn’t seem to be supported at all. The product page says it’s compatible with ‘any MCU’, but when I check the supported boards I only see ESP32 and Nano BLE mentioned. The Nano ESP32 is quite different from both of those, and there’s no documentation or example code for it. Does anyone know when ArduCAM Mega support for the Nano ESP32 will be available?
Thanks for reaching out. Just to make sure I understand the setup correctly — you’re connecting an ArduCAM Mega to an Arduino Nano ESP32, correct? And have you already tried running any of the example sketches from the library on it, or are you stuck before that point because of missing board support?
Correct, it’s the Arduino Nano ESP32 and an ArduCAM Mega. I haven’t actually gotten as far as running examples — I couldn’t find any docs or library support specifically for the Nano ESP32, and I didn’t want to guess at the wiring and pin assignments. The ESP32 and Nano BLE seem to have example code available, but there’s nothing for this board.
Got it. I can confirm that the Arduino Nano ESP32 platform isn’t supported for the ArduCAM Mega yet, so the missing docs and examples you’re seeing are expected at this point. We are actively working on adding support for the Nano ESP32. Once the adaptation and testing process is complete, we’ll update the compatibility table in the documentation, and an upcoming release will include full Arduino Nano ESP32 support. In the meantime, you can keep an eye on the compatibility table here: GitHub - ArduCAM/Arducam_Mega · GitHub
That’s good to hear it’s in progress. Do you have any rough idea of when the Nano ESP32 support will actually be available?
Support for the Arduino Nano ESP32 is still under adaptation and testing, but the current estimate is around February, after the Chinese Spring Festival. It will be reflected in the compatibility table in the documentation once it’s ready, so I’d suggest continuing to monitor that page for updates.
