Hi everyone, I’m trying to get an Arducam Mega 3MP camera to capture an image but I’m stuck on finding the right information. The getting started link I found has a document with instructions and register addresses for the older Arducam camera, but nothing equivalent for the newer Mega. Can anyone tell me what command is actually needed to take a picture on the Mega?
Thanks for the report. Just to confirm, you’re using the Arducam Mega 3MP and trying to trigger a capture from your code, correct? Could you share the exact register write you’re attempting so I can check it against the correct sequence?
Yes, that’s right. If I understand the code correctly, all I need to do is write the value 0x02 to the Fifo register at 0x04 to take a picture. I’ve tried that and so far it hasn’t worked, so I’m just checking whether this is the correct procedure for the Arducam Mega or if I’m missing something.
That write alone won’t trigger a capture on the Mega. The 0x02 write to register 0x04 comes from the older Arducam camera register set, and the Mega uses a different capture flow. You’ll want to follow the Mega-specific documentation rather than the older camera’s register document.
Please review the Arducam Mega getting started page here: https://www.arducam.com/docs/arducam-mega/arducam-mega-getting-started/index.html - it covers the proper initialization and capture sequence for the Mega specifically.
Thanks, but I’ve already looked at that getting started link and I still don’t see the instruction set for the Mega camera. There’s a document with the register addresses for the older Arducam, but nothing similar for the Mega. Could you point me to the instruction set for the Arducam Mega, including the register addresses?
To summarize where we are: writing 0x02 to FIFO register 0x04 is not the correct capture procedure for the Arducam Mega - that sequence comes from the older camera’s register map. The getting started page I linked is currently the main reference for the Mega, and it doesn’t include a standalone register-level instruction set like the older camera’s document does. I’d suggest working from the Mega library’s capture sequence shown in the getting started examples rather than using the 0x04/0x02 write. If you need the full low-level register details for the Mega, those aren’t published in the same form as the older camera, so that would need to be checked separately. For now, the key takeaway is: don’t rely on the 0x04/0x02 write on the Mega.
