Hi everyone, we’re stuck trying to get the Arducam Mega going. We can’t find the GUI application so we can’t communicate with the camera at all. We tested the Mega with 4 different boards (two Arduino Mega 2560, an ESP32 and a Raspberry Pi Pico) and the GUI we downloaded from the link that was shared earlier just throws an error every time: https://www.arducam.com/docs/arducam-mega/arducam-mega-getting-started/packs/GuiTool.html#focus-control
I’ve attached a screenshot of the error. Any idea what’s going on here? We’re trying to find the Mega cam GUI but it’s just not happening.
Hi, quick question first — are you using our example program to test it? I’d suggest starting with the sample program before troubleshooting the GUI. That way we can tell whether the board and camera are actually working.
Which sample program did you test exactly? We need to know so we can reproduce it on our side. Also, please double-check that the camera is connected properly — a loose or wrong connection would explain a lot here.
Thanks. So we ran the Mega here and it displays images normally — the hardware itself is fine on our end. That means the difference is probably in the wiring.
Can you provide a complete camera connection diagram of your setup so we can compare it against our working configuration?
Also, after running a second test with the Dupont wire we found a few errors in the documentation. You can modify the connection by referring to the figure below and test again. Note this is only for ‘Mega’ cameras — the other cameras still need to be tested, so can you also provide connection diagrams for all the cameras you’re using?
Ok so just to be sure — we need to connect it in this way (diagram attached) and run it with this code (screenshot attached), aren’t we? Want to confirm before soldering anything.
Apologies, the diagram misled you — the connection of the SPI signal is wrong. On the Arduino Mega platform, we should connect the SPI signal here instead (see the attached figure). Please reconnect your hardware following that and let me know if you need more help.
Glad to hear it’s working now. To sum up for anyone following along: the problem was the SPI signal wiring on the Arduino Mega — the original getting-started diagram was incorrect for the Mega. With the SPI signal connected to the correct pins shown in the corrected figure, the camera works normally. If you’re still testing the other boards (ESP32, Pico), send over the connection diagrams and we’ll check those too.
