Hi everyone, I’m trying to get the Arducam IMX519 (16MP) camera working on my NVIDIA Jetson Xavier NX Developer Kit. I’ve been following the official Arducam Quick Start Guide step by step.
When I run the driver installation script, it attempts to install the arducam-nvidia-l4t-kernel package but fails with this error:
Cannot find the corresponding deb package for Kernel version: 5.10.192-tegra-35.5.0-20240613202628 Jetson type: NVIDIA Jetson Xavier NX Developer Kit
It seems like it can’t find a matching package for my kernel. Has anyone run into this before? Any ideas on what I should try next?
Thanks for the details. That error means the installer couldn’t locate a pre-built driver package matching your specific kernel build. Let’s first confirm exactly which L4T kernel package you have installed.
Can you run this command and share the output?
dpkg -l | grep nvidia-l4t-kernel
That will help us pin down whether this is a version mismatch issue.
That confirms it — your kernel version 5.10.192-tegra-35.5.0-20240613202628 is a custom build of L4T 35.5.0. The arducam-nvidia-l4t-kernel package is distributed as pre-built debs for specific standard L4T releases, and your particular build timestamp (20240613202628) doesn’t have a matching package available.
Root cause: version mismatch between your installed kernel and the available driver packages.
The good news is there’s a documented way around this. Arducam has a troubleshooting guide that covers exactly this scenario — camera driver installation failures on Jetson devices due to kernel version mismatches. You can find it here:
That guide should walk you through resolving the issue — most likely by building the driver from source against your running kernel, or by using a package that targets the base L4T 35.5.0 release rather than your specific build. Give that a shot and let us know how it goes.
