Arducam integration issues on Ubuntu Mate 20.04 for ROS project
Hi, I’m trying to get an Arducam camera working on Ubuntu Mate 20.04 on my Raspberry Pi and I keep hitting errors - I just can’t get it running. I can’t move to Raspberry Pi OS because I need ROS support, and that only works for me on Ubuntu. Does anyone have a guide or guidelines for using Arducam on Ubuntu Mate 20.04? Any pointers would really help.
Hi, happy to help look into this. Before we can point you at the correct driver, we need to know exactly which Arducam product you’re using. We keep different drivers for different cameras and other devices, so the right steps depend on the exact model - without that we can’t really diagnose the errors you’re seeing. Which Arducam product do you have? And if you can paste the errors you’re getting, that would help too.
Sorry, should have said. It’s the 1MP*2 wide angle stereo camera for Raspberry Pi - the dual OV9281 monochrome global shutter one.
Thanks, that narrows it down a lot. Can you also confirm the rest of your setup? Specifically the OS version and which Raspberry Pi board you’re running. And if you can share the commands you tried plus the exact error output, that will help us figure out where it’s breaking.
Sure thing. OS is Ubuntu Mate 20.04, board is a Raspberry Pi Model 4B, and the camera is the 1MP*2 wide angle stereo camera for Raspberry Pi with dual OV9281 monochrome global shutter sensors. Really need help getting this whole combination working.
Got it, thanks for the details. I’ve forwarded this to our engineering team because the stereo camera plus Ubuntu Mate 20.04 combination needs a closer look - it isn’t something we can resolve at the support level. Logged from your info: 1MP*2 wide angle stereo camera for Raspberry Pi (dual OV9281 monochrome global shutter), Ubuntu Mate 20.04, Raspberry Pi Model 4B. The engineer will follow up here with you as soon as possible.
Quick update on this one - we’re going to try testing the camera driver on an Ubuntu system before we give you a detailed answer. The driver hasn’t been validated on Ubuntu yet, so we want to confirm how it actually behaves first. We’ll post more details here as soon as the testing is done.
It’s been a while now and I’m still getting nothing at all out of the camera - no output, no stream, nothing. I’ve been just sitting here waiting for a reply. Can someone please give me an update? I honestly don’t know what else I can try on my end at this point. Setup is still Ubuntu Mate 20.04 on a Raspberry Pi Model 4B with the 1MP*2 wide angle stereo camera, dual OV9281 monochrome global shutter.
Sorry for the wait, and thanks for your patience. Current status: the driver for the dual OV9281 stereo camera still hasn’t been validated on Ubuntu, which is why you’re getting no output. Our known working environment is Ubuntu Mate 20.04 on a Raspberry Pi Model 4B, but the stereo driver itself still needs testing/modification for Ubuntu, so there’s no confirmed fix yet. To help engineering pin down whether the sensor is even being detected, can you share: the exact commands you’re running, the output of dmesg | grep -i ov9281, and i2cdetect -y 10 (or whichever i2c bus your overlay uses)? That will tell us whether it’s a detection problem or a driver problem.
Ok, I’ll grab those. Just to be clear though - is there any chance this gets working on Ubuntu Mate 20.04 at all, or am I stuck? I don’t want to keep waiting if this combination just isn’t supported yet.
Honest answer: at the moment there’s no validated driver for this stereo camera on Ubuntu, so we can’t promise it will work yet - the Ubuntu path is still being tested and may need changes on our side. The setup itself (Ubuntu Mate 20.04 on Raspberry Pi Model 4B) is the environment we’re testing against, so if it’s going to work anywhere, that’s where. For now the best next step is to send the dmesg and i2cdetect output so we can confirm whether the camera is being detected at all, and we’ll update here as soon as the engineering test results come back. We’ll keep this thread open until there’s a concrete answer.
