Hi, hoping someone here can help. I picked up an Arducam IMX519 fixed focus camera module (NOIR), product code B0386, and I can’t get it to work on a Raspberry Pi at all.
Stuff I’ve already tried:
Several different Raspberry Pis
Several different ribbon cables, including ones that work fine with my other cameras, and the cable that came with the camera
Nothing shows up. The camera doesn’t seem to be detected at all. Any ideas?
Ran the tool, and also raspistill -v. Honestly I don’t think the camera is being electrically initialized at all.
libcamera just reports no cameras available:
[2:14:41.550704913] [1173] INFO Camera camera_manager.cpp:293 libcamera v0.0.1+54-d528119f
And the bug report was generated:
Bug report generated to arducam-bug-report.txt
Please upload this file when you contact [email protected]
raspistill says it’s not detected:
mmal: Cannot read camera info, keeping the defaults for OV5647
"raspistill" Camera App (commit )
Camera Name OV5647
Width 2592, Height 1944, filename (null)
Using camera 0, sensor mode 0
GPS output Disabled
Quality 85, Raw no
Thumbnail enabled Yes, width 64, height 48, quality 35
Time delay 5000, Timelapse 0
Link to latest frame enabled no
Full resolution preview No
Capture method : Single capture
Preview Yes, Full screen Yes
Preview window 0,0,1024,768
Opacity 255
Rotation 0, hflip No, vflip No
ROI x 0.000000, y 0.000000, w 1.000000 h 1.000000
mmal: mmal_vc_component_create: failed to create component 'vc.ril.camera' (1:ENOMEM)
mmal: mmal_component_create_core: could not create component 'vc.ril.camera' (1)
mmal: Failed to create camera component
mmal: Camera is not detected. Please check carefully the camera module is installed correctly
Host is a Raspberry Pi (hostname raspberrypi, user alias), libcamera v0.0.1+54-d528119f.
Thanks, I can see the problem now. You only need the imx519 driver. It looks like you also installed the 64mp camera driver, and that overwrites the imx519 entry in the config file — that’s why the camera isn’t working.
Please do this:
Run sudo nano /boot/config.txt and delete the line dtoverlay=arducam_64mp under [all] at the bottom of the file.
OK, big improvement. I rebuilt the Pi system and fully updated it, then installed the driver you said, and the camera is now reading — that made a considerable difference. But now I’m getting a memory error when I try to save a picture. Please see attached.
No rush — I can actually see there’s already an arducam-bug-report.txt sitting on the path ~. Just send that one over so I can read your Pi’s config and continue.
