Arducam IMX477 on Jetson NX2 with JNX30D: install script fails, need ISP tuning
Hi everyone, I’m integrating the Arducam IMX477 MIPI camera (b0249) into an NVIDIA Jetson Xavier NX product. The camera is connected to an Auvidea JNX30D carrier board and I’m running JetPack 4.6. I need help tuning the ISP and all camera parameters for this integration, and I’m also looking for any app/utils I can use to do the tuning. One more thing — can someone confirm if a 22-to-22 pin cable is okay for this setup, and whether we need specific drivers for JetPack 4.6 on the NX2?
Thanks for the details. Let’s start with the driver/install side first. Can you post the exact output from the install script you ran, plus the output of uname -a? That will show which kernel and board the script is detecting.
Sure, here’s what I did. Downloaded the script:
2023-05-05 19:19:38 (5.84 MB/s) - ‘install_imx477.sh’ saved [15707/15707]
Then:
poker@poker-desktop:~$ chmod +x install_imx477.sh
poker@poker-desktop:~$ sudo ./install_imx477.sh
Output:
Kernel version: 4.9.253-tegra-32.6.1-20210726122859
Jetson type: UNKNOWN
Then I checked the kernel:
poker@poker-desktop:~$ uname -a
Linux poker-desktop 4.9.253-tegra #1 SMP PREEMPT Mon Jul 26 12:19:28 PDT 2021 aarch64 aarch64 aarch64 GNU/Linux
I’ve also attached a screenshot of the error.
Got it, thanks. The ‘Jetson type: UNKNOWN’ message means the installer couldn’t match your board/kernel combination to one of the available deb packages. Your kernel 4.9.253-tegra-32.6.1-20210726122859 on that carrier board isn’t being recognized by the script’s detection. On the cable question, the 22-to-22 pin cable is the standard one for these MIPI connections, but right now the immediate blocker is the script not finding a matching deb for this kernel.
Understood. So does that mean the drivers can’t be installed on JetPack 4.6 for the NX2? And separately, do you have ISP tuning tools or configuration files for this camera? We specifically need to tune the ISP effects and camera parameters.
On the ISP side, I checked with the team: the Jetson platform does not support ISP effects, and there are no corresponding ISP configuration files available. The ISP effects on Jetson devices are proprietary to NVIDIA and are not publicly accessible, so Arducam cannot provide ISP tuning or ISP configuration files for Jetson.
Ah, that’s disappointing. So there’s no way to adjust ISP parameters on Jetson at all, even through some utility?
Correct — we can’t provide ISP tuning or configuration files for the Jetson platform. The ISP effects are NVIDIA proprietary and aren’t exposed publicly, so there’s nothing Arducam can supply for ISP tuning on Jetson. For the install script issue with your kernel, we can still look at suitable alternatives, but on ISP tuning specifically that’s not something we can provide for this platform.
