Hey everyone, I’m having trouble getting my Arducam IMX477 Autofocus Camera (UC-517 Rev.D3) working on my NVIDIA Jetson Orin Nano Developer Kit. The camera isn’t being detected at all. I tried the default Jetson drivers and also tried configuring it via jetson-io with the standard IMX477 settings, but nothing works. I checked and I’m getting an I2C probe error -121 when the system tries to talk to the camera. Any ideas what could be going wrong?
Thanks for reaching out! The I2C error -121 (Remote I/O error) usually means the system can’t access the sensor registers. Could you first run this command in a terminal and share the output?
sudo dmesg | grep imx
Also, could you take a couple of clear, high-resolution photos showing:
- The orientation of the FPC ribbon cable on the Jetson CSI port (the “gold fingers” side)
- How the cable is seated on the camera module side
Mismatched ribbon cable orientation is actually the #1 cause of -121 errors on Jetson boards. Also, for Arducam’s motorized focus modules like the UC-517, the standard jetson-io configurations can sometimes conflict with the onboard motor driver logic. You might end up needing the dedicated Jetvariety driver package instead. Here’s a reference: Quick-Start-Guide - Arducam Wiki
Okay, here’s the output from sudo dmesg | grep imx:
[ 12.318263] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[ 12.328962] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 12.343397] imx219 9-0010: board setup failed
[ 12.347968] imx219: probe of 9-0010 failed with error -121
[ 12.361181] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[ 12.373300] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 12.387887] imx219 10-0010: board setup failed
[ 12.395982] imx219: probe of 10-0010 failed with error -121
So… it looks like the system is trying to load an IMX219 driver, not an IMX477 driver? That seems wrong. I double-checked the ribbon cable orientation too and it’s seated correctly on both ends.
You’ve nailed it. That’s exactly the issue. Your Jetson is loading the driver for an IMX219 sensor (8MP), but your hardware is an IMX477 (12.3MP). The IMX219 driver is looking for a different hardware ID and I2C address than what the IMX477 provides, so the probe fails with -121.
To fix this, you need to install the correct IMX477 driver. Run these commands:
cd ~
chmod +x install_full.sh
sudo ./install_full.sh -m imx477
After it finishes, reboot the Jetson. Once that’s done, check if /dev/video0 shows up. If the video stream works, you can then control the autofocus motor using the scripts here:
I tried running the install script but it failed. Here’s what happened:
The script detected my hardware but then returned: “Cannot find the corresponding deb package”
My environment:
- Kernel version: 5.10.216-tegra-35.6.0-20240828020325
- Jetson: NVIDIA Orin Nano Developer Kit
Seems like it can’t find a pre-compiled package for my kernel version.
That error makes sense. The script looks for a pre-compiled driver package matching your exact kernel version, and it looks like Arducam hasn’t published a package yet for kernel 5.10.216-tegra-35.6.0-20240828020325.
You have two options:
Option 1 (Recommended for full Arducam features): Re-flash your Orin Nano to a JetPack version from Arducam’s supported list. Check their compatibility table here:
https://docs.arducam.com/Nvidia-Jetson-Camera/Introduction-to-Arducam-Jetson-Cameras/#official-nvidia-orin-nano-development-kit
Option 2 (Quickest workaround): Use NVIDIA’s built-in native IMX477 driver via jetson-io. The Jetson platform actually includes a native driver for the IMX477 sensor (same sensor used in the Raspberry Pi HQ Camera). Here’s how:
- Open a terminal and run:
sudo /opt/nvidia/jetson-io/jetson-io.py - Navigate to: Configure Jetson for compatible hardware → Camera → Dual-IMX477
- Save the configuration and reboot when prompted.
After rebooting, the system should detect the IMX477 camera properly. You can test it with:
gst-launch-1.0 nvarguscamerasrc ! autovideosink
This won’t give you Arducam’s custom autofocus controls via their scripts, but it will get the camera working with standard apps. Let me know how it goes!
