Arducam IMX477 kernel issue on jetpack 6.2
I flashed my jetson orin nano with jetpack version 6.2. I have arducam imx477 camera and i cant find any kernel or repo supporting the 6.2 version.
This is the errror message i get:
(Reading database … 190587 files and directories currently installed.)
Preparing to unpack arducam-nvidia-l4t-kernel-t234-nx-5.15.148-tegra-36.4.3-20250205154643_arm64_imx477.deb …
Unpacking arducam-nvidia-l4t-kernel (5.15.148-tegra-36.4.3-20250205154643) over (5.15.148-tegra-36.4.3-20250205154643) …
ls: cannot access ‘nv_imx477.ko.bak’: No such file or directory
Setting up arducam-nvidia-l4t-kernel (5.15.148-tegra-36.4.3-20250205154643) …
mv: cannot stat ‘/boot/arducam/arducam_csi2.ko’: No such file or directory
The installation command i am using is:
chmod +x install_full.sh
./install_full.sh -m imx477
Once you see ‘Setting up arducam-nvidia-l4t-kernel…’ pop up, you’re good to go! Just run ‘ls /dev/video0’ and ‘dmesg | grep imx477’ to double-check.
Hey the camera is working fine but there are some issues with capturing images and the focus is also manual.how can i take forward with capturing images?
Which IMX477 camera module did you purchase?
