Hi, I’m trying to install the ArduCam driver for an IMX477 camera on my Jetson Nano using install_full.sh, but it keeps failing with: “Cannot find the corresponding deb package, please send the following information to [email protected]”. It basically says there’s no suitable deb package for the current kernel. Has anyone run into this?
Could you share a few details so we can figure out why the script can’t match a package? Specifically your kernel version, the Jetson board model, and which camera you’re using.
Sure. Kernel version is 4.9.337-tegra-32.7.4-20230608212426, board is an NVIDIA Jetson Nano Developer Kit, and the camera is an IMX477. I already ran install_full.sh for the ArduCam driver install and also asked support for a matching deb package, but I haven’t gotten anywhere yet.
The main issue is your L4T version. 32.7.4 isn’t in the Arducam supported version list, so install_full.sh can’t find a corresponding deb package for that kernel. You’ll need to reflash JetPack to one of the supported versions listed in the Arducam Jetson camera documentation: Introduction to Arducam Jetson Cameras - Arducam Wiki
To add to that: the Arducam Jetson camera drivers/deb packages are only built for supported JetPack/L4T versions. When the kernel version is unsupported, the install_full.sh script just reports that no corresponding deb package can be found. Once you’re on a supported L4T, it should be able to locate the right package.
Got it, thanks. I’ve now moved to L4T 32.7.3, but now I can’t find the deb package for that version. The MIPI_Camera repository only seems to contain packages for the Nano module. Here’s a screenshot of what I see:
That package is there, it’s just on a different page of the GitHub releases. The MIPI_Camera deb packages for various L4T versions are spread across multiple pages. The L4T 32.7.3 package you need is on page 2: Releases · ArduCAM/MIPI_Camera · GitHub
So to wrap up: go to Releases · ArduCAM/MIPI_Camera · GitHub and locate the L4T 32.7.3 deb package there, then download and use that one for your IMX477 setup.
