Hi all, hoping someone can help. I’ve got a Raspberry Pi with a completely fresh Raspberry Pi OS install and an Arducam IMX477 Motorized Focus Camera. I went through the quick start guide step by step here: For 12MP IMX477 Motorized Focus Camera - Arducam Wiki
Everything seemed to go fine during setup, but afterwards the camera just isn’t detected. libcamera-hello reports ‘no cameras available’ and vcgencmd get_camera shows supported=0 detected=0. Since the OS was just flashed, I don’t think it’s leftover config from a previous install. Where should I start looking?
Hi, thanks for posting. Could you run the Arducam bug report script and attach the generated file? It’ll give us a look at the OS version, config, overlays and what the detection tools actually see. Also, which Pi model are you on, and did you enable the camera interface (raspi-config or otherwise) before testing?
Here’s the bug report output — arducam-bug-report.txt attached. I’ve read through it but nothing stands out to me. Camera interface is enabled and I’ve rebooted a couple of times. Still nothing in libcamera and vcgencmd get_camera still reports detected=0.
Thanks, I went through the log. To be honest nothing in there points to an obvious software cause yet — the IMX477 just isn’t being enumerated at all. Before I go deeper on the software side, could you upload a few pictures of the hardware connection? I’d like to see the ribbon cable at both ends (camera board and Pi), the orientation of the contacts, and how the motorized focus board is connected. A surprising number of these ‘not detected’ cases end up being a cable that’s reversed or not fully seated.
Sure, I’ll grab some photos and post them. While I’m at it — is the ribbon orientation on the IMX477 motorized focus camera the same as a standard Pi camera? Anything specific I should watch for on the motor board connection?
Thanks, photos will help a lot. Yes, orientation matters the same way as a standard camera — the ribbon contacts need to face the right direction at both connectors and the cable has to be fully seated and straight. For the motorized focus version, also check the small link between the focus motor board and the sensor board hasn’t worked loose.
To summarize where this stands: the camera isn’t detected after a fresh Raspberry Pi OS install, and the bug report doesn’t show a clear software cause yet, so the root cause is still open. We’re waiting on the hardware connection pictures before deciding the next step. If you can upload those, I’ll take a look and we’ll go from there.
