Arducam IMX462 STARVIS camera overexposed in sunny outdoor video with libcamera-vid
I’ve got an Arducam Ultra Low Light 2MP IMX462 STARVIS camera hooked up to my Pi. Indoors it works fine and adjusts exposure normally when the lighting changes. But when I take it outside on a sunny day, the video feed is overexposed - almost pure white. I’m using libcamera-vid -t 0 for the live stream.
Thanks for the report. Can you share a short clip of the overexposed feed? It would help us diagnose it. If possible, run libcamera-vid -t 5000 -o test.h264 and attach the resulting file. The weather here has been cloudy and rainy, so I can’t reproduce it outdoors right now, but I’ll test on our side once it’s sunny.
Here’s the clip I generated with libcamera-vid -t 5000 -o test.h264, plus a bug report file. Indoors the same camera adjusts exposure fine under different lighting, but outdoors in bright sunlight it’s almost completely white. Hopefully the video shows the problem clearly.
Thanks, I’ve got the clip and the bug report. I still haven’t had a sunny day here to reproduce it myself, but I’ll do an outdoor test as soon as the weather clears and follow up with what I find.
Just checking in - any progress on the outdoor overexposure? The indoor behavior is still totally normal, and only bright sunlight causes the white-out. I can generate another clip if that would help.
Sorry for the delay. I finally got a sunny day and was able to reproduce the overexposure with the same setup. My current suspicion is a high gain mode in the firmware. I’m going to check the firmware and try closing or disabling high gain mode. I should have more news next week.
Thanks for the update. Any luck with the firmware change? I’m still seeing the same white-out in sunlight, just in case that’s useful for your testing.
I tested the camera again on Monday and tried a firmware modification, but the sunlight behavior is still bad. Our chief engineer looked into it and said the IMX462 is designed as a low-light sensor, so bright outdoor sunlight doesn’t really match this camera’s characteristics. For a better exposure effect outdoors, the imx708 camera is the better fit because it has HDR. You can search for it here: Search results for: 'imx708'
