Hi all,
I installed IMX219 https://www.amazon.com/dp/B09VSS74L2?th=1 on the rpi5. But the libcamera-hello says “no camera available”.
Tried on camera 0 and camera 1, cable came with the camera
set “camera_auto_detect=0” and add “dtoverlay=imx219” on the /boot/config.txt
Power supply is not official but it provide 3A (when booting up)
Any help appreaciated.
Thanks
Dion
January 24, 2024, 1:41am
2
Can you follow the steps below and put the generated bug-report into the google drive or other cloud storage and post the link here:
Reboot your device.
Execute the following command to download the bug report tool:
Set executable permissions for the tool:
Execute the tool to generate the bug report:
This will output an “arducam-bug-report.txt” file in the current directory.
I managed to make it work with
#Automatically load overlays for detected cameras
#camera_auto_detect=1
dtoverlay=imx219,cam0
Thanks
Dion
January 30, 2024, 6:17am
4
That’s what I want you to do. Because Pi 5 has two csi interfance. If you enable the camera driver in the config file with “dtoverlay=imx219 ” and connect the camera to csi 0 port, Pi 5 will not detect this camera module.
I see. I tried with only “dtoverlay=imx219” and it works on csi 1 port. Guess will need to specifically specify the port.
Thank you for the respond.
