Arducam IMX219 Multi-Camera Kit never worked on Jetson Orin AGX
Hi everyone, I’m trying to get the Arducam IMX219 Multi-Camera Kit working on a Jetson AGX Orin, but it has never worked since I got it. I’ve been following the Quick Start Guide here: Quick Start Guide - Arducam Wiki
I run sudo ./install_full.sh -m imx219 and it fails. I can attach the error logs and platform info if that helps.
Thanks for posting. Before we dig into the logs, can you confirm which Jetpack version is on the AGX Orin? Please check it against the supported list for the official NVIDIA Jetson AGX Orin Development Kit here: Introduction to Arducam Jetson Cameras - Arducam Wiki
Also, what hardware version is your Jetson AGX Orin? It’s usually printed on the package box. A photo of the board would help too.
I’ve attached the error logs and the platform info I pulled from the Orin. I don’t have the hardware version noted down separately, but the platform info file should show what you need. Let me know if you need anything else.
Thanks, I’ve received the info. Could you also send a picture of the Jetson AGX Orin itself? And please run sudo ./install_full.sh -m imx219 one more time, then send the full output of dmesg right after. That should show where it’s actually failing.
Here’s a picture of the Jetson Orin AGX, plus the logs you asked for. One thing I want to double check: the errors I’m seeing were captured on a system that is no longer connected to the Arducam. It was connected to the same Arducam before and hit the same issue. Is it okay to run install_full.sh without the cameras plugged in? I assumed yes, but I want to confirm. The notes are in the attached arducam.md file.
Thanks, I’ve got the picture and the logs. I’m still working through the dmesg output to figure out where the install is failing. Regarding your question about running install_full.sh with no cameras attached — I’ve noted that down and will confirm, but the fact that the same error shows up both with and without the Arducam connected is actually useful for narrowing this down. I’ll update once I’ve finished reviewing the logs.
