Arducam IMX219 does not work on Raspberri Pi4.
I have two cameras and multiple flatwires, and the two IMX219 cameras worked on NVIDIA Jetson board with gst-launch-1.0 command.
But, when I tried them on Raspberri Pi4, they did not work. I had enabled cameras through configure, and connection was correct.
The error is:
sudo vcgencmd get_camera
supported=1 detected=1
sudo raspistill -t 0
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
mmal: camera component couldn’t be enabled
mmal: Failed to run camera app. Please check for firmware updates
I have run sudo rpi-update and rebooted, the same error.
GPIO_MEM changed to 256. Camera was put in the interface between HDMI and USB.
