Arducam IMX219 camera output issue with libcamera-hello on Raspberry Pi 5
Hi everyone. I’ve got an Arducam IMX219 visible light fixed focus camera module (SKU B0390) connected to a Raspberry Pi 5 through the CSI port. When I run libcamera-hello -t 0, I don’t get a preview — the command output is full of errors. I’ve attached the output as first.png. I’m not sure if this is a wiring problem, a config problem, or something else.
Welcome. Could you post the full text output and a bit more about the system? On the Pi 5, run uname -a so we can see the kernel, and grab the system log right after the failed command using journalctl -k or dmesg. Also, are you running stock Raspberry Pi OS, or something custom?
Sure. I ran uname -a and grabbed a few system info screenshots, plus the system log after the failure. I attached them: uname -a.png, Screenshot from 2024-12-16 14-08-16.png, Screenshot from 2024-12-16 14-09-38.png, Screenshot from 2024-12-16 14-11-41.png, Screenshot from 2024-12-16 14-11-55.png, and Screenshot from 2024-12-16 14-13-21.png for the log. The only command I’ve tried is libcamera-hello -t 0.
Thanks, that helps. I noticed from your earlier posts that you also have the Arducam 1MP 4 Quadrascopic Camera Bundle Kit IMX219 (B0396). Can I check something — for this test, did you detach one of the imx219 modules from that B0396 kit and connect it directly to the Pi 5’s CSI port?
Yes, I did. I took one of the four imx219 modules off the B0396 HAT kit and connected it straight to the Pi 5. I figured since it’s the same IMX219 sensor it would behave like the standalone B0390.
That’s likely the root cause. The imx219 modules in the B0396 quadrascopic camera bundle are designed to work through that kit’s camera HAT, and they’re not directly compatible when connected straight to a Raspberry Pi. The B0396 kit modules aren’t interchangeable with the standalone B0390 IMX219 module, even though the sensor part is the same. So don’t connect a camera taken from the B0396 kit directly to the Pi 5. If you have a genuine B0390 module, test that one with libcamera-hello -t 0 — the direct CSI connection should be recognized normally. If you’re still seeing errors with a true B0390, post the log text here and we can dig further.
