Hi everyone. I’m running two Arducam IMX-477 cameras on an NVIDIA Jetson Nano Developer Kit and I recently updated the Jetson because some other software I needed had a dependency that forced the update. After that update, the camera drivers just won’t load anymore. I tried reinstalling them and that doesn’t work either. Has anyone seen this?
That’s frustrating. Could you post a few details so we can pin it down? Specifically your kernel version (uname -r), the exact Jetson model/board, and how many cameras you have connected. Also, if you have the exact error output from the driver install, please paste it here.
Sure. Kernel version is 4.9.337-tegra-32.7.4-20230608212426. It’s an NVIDIA Jetson Nano Developer Kit, and I have two Arducam IMX-477 cameras attached. When I try to reinstall the drivers, the installer fails and prints: “Cannot find the corresponding deb package, please send the following information to [email protected]”. I’ve retried the install a few times and I keep getting the same message, so I can’t get the drivers back in.
Thanks, that error is the key clue. It basically means the installer can’t find a matching driver package for your current L4T version. I checked our available releases, and it looks like Arducam has NOT yet released the IMX477 camera driver for L4T version 32.7.4. So on that kernel there simply isn’t a corresponding deb package for the installer to grab.
Ah, so that’s why the install can’t complete. Is there any workaround, or do I need to change something on the board to get the two IMX-477s working again?
Right, the root cause is that your Jetson got updated to L4T 32.7.4, but we haven’t released an IMX477 driver for that L4T version yet. Since no matching driver/deb package exists for 32.7.4, the drivers fail to load and can’t be reinstalled. The cleanest fix is to burn/reflash JetPack to one of the supported versions listed here: Introduction to Arducam Jetson Cameras - Arducam Wiki
Got it. So I shouldn’t try to just downgrade the kernel alone? It sounds like I need to reflash the whole JetPack version to a supported one, correct?
Correct. The IMX477 driver is not available for L4T 32.7.4, so to use your Arducam IMX-477 cameras you’ll need to revert the system to a supported JetPack/L4T version. Best approach is to reflash JetPack to one of the versions on that supported list, then reinstall the camera drivers from there. Once you’re back on a supported version, the installer should find the right package and the drivers should load normally again.
