Arducam HDMI to CSI extender not detecting cameras with Camarray HAT on Raspberry Pi 5
Hi all, hoping someone can help because I’m going in circles with this.
I’m trying to use a camera array module with a CSI to HDMI extender cable and the cameras just aren’t detected.
My setup:
  • Arducam Camarray HAT board
  • 4x 64MP Hawkeye cameras
  • Arducam HDMI to CSI extender
  • Raspberry Pi 5
What I’ve tried so far:
  • All four 64MP Hawkeye cameras connected with the normal ribbon cables — that works fine.
  • Full power down and unplug/replug of everything
  • Running my older code that used to work
  • Next I’m going to try some Ugreen HDMI cables
A couple of questions:
  1. Is it even possible to use the CSI to HDMI connector and the Camarray HAT together?
  2. The instructions specify HDMI 1.2 — would a different HDMI cable version stop it from working?
Thanks for the detailed report.
First, to be clear about what’s supported: the only supported way to connect the Raspberry Pi and the Camarray HAT board is through an HDMI extension kit. Directly connecting four camera modules to the HAT board’s slots will exceed the data transmission capabilities, so that’s not a viable setup.
For the extension kit, cable length and quality matter a lot — for stable data transfer you want a Ugreen HDMI cable under 2 meters.
Now, one thing I need to pin down: in your current wiring, is the HDMI-CSI extender sitting between the 64MP camera module and the HAT board?
Yes — the HDMI-CSI extender is between the 64MP camera module and the HAT board.
To restate the symptom: the Camarray HAT works when all four 64MP Hawkeye cameras are connected using the ribbon cables. When I use the HDMI-CSI extender, the cameras are not detected.
I’ll try the Ugreen HDMI cables and report back.
We don’t support this way, as I mentioned in my previous message.
Please note that directly connecting four camera modules to the HAT board’s slots will exceed the data transmission capabilities, and therefore is not a viable setup.
The supported approach is to use the HDMI extension kit between the Raspberry Pi and the HAT board — not between the camera modules and the HAT. Keep the Ugreen cable under 2 meters for stable data transfer.
So to summarize: the HDMI-CSI extender on the camera-to-HAT side is an unsupported configuration, and the cameras not being detected is consistent with that. The working ribbon-cable setup confirms the cameras themselves are fine.
