Hey everyone, I’m stuck with my Arducam Hawkeye 64 (64MP module) on a Raspberry Pi 5 running the latest OS. It was working on the CAM1 port, but I moved it to CAM0 because of my case layout, and now libcamera can’t see it at all.
I updated /boot/config.txt to:
dtoverlay=arducam-64,cam0
And dmesg actually shows the device:
[ 4.785047] arducam_64mp 6-001a: Device found Arducam 64MP
Thanks for the log output — that’s a useful clue. The kernel clearly finds the sensor at I2C address 6-001a (‘Device found Arducam 64MP’), but libcamera reports no cameras, which usually points to an overlay/config or physical connection issue rather than a dead camera.
Can you post pictures of the connection on both ends (the Pi side and the camera side)? Also, please generate a bug report so I can review the full configuration. Let me know and I’ll post the exact steps for the bug report.
Problem: moved the camera from CAM1 to CAM0 and changed config.txt to dtoverlay=arducam-64,cam0. Both libcamera-hello and libcamera-still return ‘Error: *** no cameras available ***’.
Environment: Arducam Hawkeye 64 (Arducam 64MP) on a Raspberry Pi 5 running the latest OS. Following the guide at: Quick Start Guide - Arducam Wiki
Config: dtoverlay=arducam-64,cam0
Logs:
dmesg | grep arducam → [ 4.785047] arducam_64mp 6-001a: Device found Arducam 64MP
libcamera-hello → Error: *** no cameras available ***
libcamera-still → Error: *** no cameras available ***
I’ve verified detection via dmesg. I attached photos of the wiring on both ends and sent the arducam-bug-report.txt through private message.
Looking at your photos, I notice you’re using a standard Raspberry Pi official cable. The 64MP module actually ships with a 22-15 pin FFC cable in the box, and that’s the cable that tends to work reliably with the Pi 5 connection. Can you try swapping in the included 22-15 pin FFC cable and see if that changes anything?
Ah, that’s part of the problem actually. The cable that came with the camera didn’t fit the Pi 5 header, so I had to use a different cable that fits. With the cable I’m using now, the camera worked fine when it was on the Disp/Cam 1 port. I only moved it to CAM0 because of my case.
Okay, that’s important — since the camera worked on Disp/Cam 1 with the same cable and only fails on CAM0, the CAM0 port itself may be defective rather than the camera or cable. I’d suggest testing the camera back on Disp/Cam 1 to confirm it still works there, and if you have another module, try it on CAM0 to check the port. If it works on Disp/Cam 1 but not CAM0, that points to a bad CAM0 port on the Pi 5.
