Kubii
EK030 with serial number : 3272496313125
Arducam108Mp with USB3 CameraSHield and official USB3 cable.
Linux Ubuntu 22.04 + Python 3.11 + ArducamEvKSDK (GitHub - ArduCAM/ArduCam_EVK_Demo )
Readme from : GitHub - ArduCAM/ArduCam_EVK_Demo (Python)
I am unable to get the documentation to :
setCtrl (exposureTime, focus, Gains, etc.)
start a threaded capture as in GitHub - ArduCAM/ArduCAM_USB_Camera_Shield_Python_Demo
New SDK seems to break compatibility with this Demo repo
API documentation to be able to set and get camera controls using new python Evk SDK. At least methods prototypes used in SDK Python Demo example
Regards,
Edward
August 21, 2023, 3:32am
3
@medalkiller
Please refer to this example
import argparse
from ArducamEvkSDK import *
def main(config_path: str):
camera = Camera()
param = Param()
param.config_file_name = config_path # a path of config file
param.bin_config = config_path.endswith(".bin") # if the config file is a bin file
if not camera.open(param): # open camera, return True if success, otherwise return False
raise Exception(f"open camera error! {get_error_name(camera.last_error)}") # get the last error message
camera.init() # init camera
camera.start()
# show all controls
for ct in camera.controls:
print(f"{ct.name}({ct.func}): range({ct.min}:{ct.min}:{ct.step}), default={ct.default}")
camera.set_control("setFramerate", 1) # set framerate to 1 fps
This file has been truncated. show original
Our new documentation:
https://www.arducam.com/docs/arducam-evk/
The beta version is to replace the original ArducamSDK
It is under development (is a beta version)
Thank you for trying this beta version, if you have any questions or suggestions please let me know
