Hi all, I’m stuck trying to get my Arducam cameras working on an NVIDIA Orin NX Developer Kit. I’ve got two AR0234 global shutter cameras (B0429), two of the AR0234 USB2.0 eval kits (EK031), two IMX477 HQ modules (B0251), and a couple of the 180° fisheye lenses (LN031). I followed the product documentation, but the install keeps failing on the Orin. Anyone else hit this?
Can you paste the exact errors from the install script? Also let me know the JetPack/L4T version on the kit and how the cameras are connected (CSI vs USB). That’ll help figure out where it’s breaking.
Here’s what I get when the install runs:
RuntimeError: No DTB found for NVIDIA Orin NX Developer Kit!
dpkg: error processing package arducam-nvidia-l4t-kernel (–install):
I also filled out the technical support form and sent it over in a private message with the rest of my setup details.
Thanks, I got the form. From those logs, the ‘No DTB found for NVIDIA Orin NX Developer Kit’ error means the installer can’t match the device tree for your board. That causes the dtoverlay step to fail, and then the arducam-nvidia-l4t-kernel package’s post-install script exits with status 255 - which is why dpkg reports the error and the package never finishes installing. I also noticed in the form you mentioned a green color cast on the USB Camera Shield Receive. That looks like a separate symptom from the install failure - is that on the same kit?
Yeah, the USB Camera Shield Receive image has a pretty strong green tint. I wasn’t sure if it was tied to the install problem or if the camera itself is bad. Is it defective?
It’s not a defect in this case. The USB Camera Shield Receive outputs raw data from the sensor and doesn’t have the ability to adjust ISP settings. Because of that, a green color cast can be normal and expected for this camera.
Okay, so it’s just raw output. Is there anything I can do to dial the colors in, or is that pretty much how it’s going to look?
Right - the root cause is that the camera outputs raw data without ISP adjustment capability, so the green cast is a characteristic of the raw data itself. You can try reducing it using the config file for the AR0234 here: ArduCAM_USB_Camera_Shield/Config/USB2.0_UC-980_Rev.B/MIPI/AR0234 at master · ArduCAM/ArduCAM_USB_Camera_Shield · GitHub . I’ve also sent you the newer version of the upper software via private message - check your inbox and try it. Heads up: adjusting the color settings may reduce the green cast but may not completely remove it. To wrap up: the green cast is expected with raw output, and the config file plus updated software is the workaround. The Orin NX install failure (No DTB found / post-install exit 255) is still open on my side - I’ll keep digging into the device tree issue for your board.
