Hi everyone, I’m working on a stereo vision project using NVIDIA Jetson Xavier NX and we recently ordered the Arducam 12MP*4 477P Quadrascopic Camera Bundle Kit (SKU B0397) with the Camarray HAT. After some initial testing, we’ve realized our application only needs 2 synchronized cameras, not 4.
Before we go further, I have a few questions:
Can we reliably use only 2 cameras with the Camarray HAT from the quad kit for long-term production use? We don’t want to run into stability issues down the line.
Are we able to mix different camera models on the same Camarray HAT, or does it require identical sensors across all ports?
If a camera module or HAT fails during deployment, can we purchase individual replacement parts, or do we need to buy a whole new kit?
What kind of technical support does Arducam provide during development? Any limitations we should know about?
Appreciate any insights from those who’ve worked with this hardware.
Good questions. Let me address the 2-camera situation first since that’s the most critical one.
There are two paths here:
Option A (STRONGLY RECOMMENDED for production): Use the dedicated 2-camera stereo kit — SKU B0265N, the Arducam 12MP*2 Synchronized Stereo Camera Bundle Kit for Jetson Nano/Xavier NX. It comes with two 12.3MP IMX477 camera modules, CS lens mounts, and the Camarray Stereo Camera HAT that’s purpose-built for two cameras. This is what you want for any deployment scenario.
Option B (NOT recommended for production): You can technically configure the 4-camera HAT from your B0397 kit into dual-channel mode via I2C. But — and this is important — the system still requires all four camera ports to be physically occupied for initialization to complete correctly. So you’d need dummy cameras or unused modules plugged into the other two ports just to boot. This adds unnecessary complexity and is known to be prone to instability. It’s really meant for evaluation, not field deployment.
Given you’re already looking at production, I’d strongly suggest pivoting to the B0265N rather than trying to make the quad HAT work in a reduced configuration.
Thanks for the detailed breakdown on the 2-camera setup — that makes a lot of sense. We’ll look into the B0265N kit.
A couple of follow-ups on the other points:
On mixing camera models — we were curious if, say, we could run two IMX477 modules alongside two different sensors on the same HAT for a different project. Is the driver flexible enough for that, or is it locked to identical sensors?
On replacement parts — can you confirm that individual camera modules and HATs are sold separately? We’re planning for long-term maintenance and don’t want to stockpile full kits just to swap one failed camera.
Also curious about what level of support your team offers during the development phase. We’re making a fairly significant hardware commitment and want to understand what we can expect.
On mixing camera models — no, that’s not supported. The Camarray HAT’s driver and the hardware synchronization design both assume identical sensors across all channels. The timing, frame sync, and image pipeline are calibrated for matching modules. If you introduce different sensor models, you’ll get inconsistent frame timing, different resolutions, and the sync logic will break down. You’d need separate HATs for different sensor types.
As for replacement parts — yes, camera modules and HATs are available individually. If a single camera fails in the field, you can order just the replacement module. No need to buy an entire kit.
Regarding support — our technical team covers implementation guidance and troubleshooting during your development cycle. That includes things like driver configuration, I2C setup, sync validation, and general integration questions. For formal SLAs, supply chain guarantees, and commercial-scale terms, those go through our sales team. I’d recommend reaching out to them if you’re planning production volumes so they can set up the right structure upfront.
If you have further questions about your specific hardware evaluation or want to discuss whether the B0265N is the right fit for your stereo application, feel free to follow up — happy to dig deeper.
