Hi, I’m having trouble getting my Arducam 64MP camera to work on my Raspberry Pi. The camera shows up as being detected in the bug report, but it says it was unable to start the camera. Anyone know what’s going on?
Hey there, happy to help you get this sorted. Can you tell me a bit more about your setup? What Pi model are you using, how is the camera connected, and what have you tried so far?
Sure. It’s a Raspberry Pi 4, with the Arducam 64MP camera connected to it. I already enabled i2c through raspi-config. I also tried replacing the cable between the Pi and the camera, just in case it was a bad connection, but that didn’t change anything. I ran the bug report and it detects the camera but still reports that it’s unable to start it.
Thanks, that’s helpful. Could you paste or attach the bug report output so I can look at the details? There should be a text file it generates.
Here it is: arducam-bug-report.txt (attached). Let me know what you spot.
Got it, thanks. The camera being detected but failing to start typically points to a memory/buffer allocation problem rather than a wiring or detection issue. I’d like you to take a look at item 7 in the Arducam 64MP camera troubleshooting documentation. I know the heading references Pi 0 / Pi 3, but don’t worry about the title since you’re on a Pi 4 — the principle is exactly the same.
Okay, I’ll check it out. Just to confirm, is the fix in that section safe to apply on a Pi 4 even though it’s titled for Pi 0 / Pi 3?
Yes, correct. The “Failed to allocate buffers” fix in section 7 applies regardless of the Pi model — it works for the Pi 4 too, even though the heading only mentions Pi 0 and Pi 3. Go ahead and follow the steps there and let me know how it goes.
Here’s the section I found: Redirecting... — this is the one you meant, right?
That’s the one. To summarize where we’re at: your camera is detected but fails to start, which matches the “Failed to allocate buffers” issue covered in item 7. The root cause is buffer allocation, not detection or cabling — which is why enabling i2c and swapping the cable didn’t help. Applying the steps in item 7 should resolve it, and the same principle applies to your Pi 4 despite the Pi 0 / Pi 3 heading. Let us know if you hit any snags along the way.
