Arducam Camera Module 3 never worked on Raspberry Pi 4, assistance only in hidden forum
Hey everyone, I’m struggling to get my Arducam working on a Raspberry Pi 4. The camera is detected on the I2C bus but picamera2 keeps throwing errors when I try to initialize it. I’ve tried the usual libcamera-hello test and it just times out. Anyone else run into this?
Sorry to hear you’re having trouble. Before we dive into software debugging, could you post a couple of photos of your hardware setup? One of the Raspberry Pi end (showing how the ribbon cable is seated) and one of the camera module end. It’s also worth generating a bug report so we can see what’s going on under the hood. Here’s how:
  1. Reboot your Pi
  2. Run these commands:
That’ll spit out an arducam-bug-report.txt file in your current directory. If you can attach that here, I’ll take a look and see what’s going on.
Thanks for the quick reply. Before I run that though — I actually managed to figure it out on my own. I stumbled across an updated forum post that was kind of buried and not linked from the main Arducam site. It had the exact config changes I needed for picamera2. Would have saved me hours if it was easier to find.
Glad you got it sorted! Could you share the link to that forum post? I’d like to see what resolved it for you, and it might help me flag the visibility issue internally so others don’t run into the same dead end.
Sure — the doc that actually helped was this one:
Not exactly a forum post per se, but it was referenced in a thread I found after a lot of digging. The key for me was the section on tuning files and understanding how picamera2 handles non-standard camera modules differently from the legacy stack. Once I pointed the config at the right tuning file, everything came up fine. Honestly, Arducam could save a lot of people pain by putting a note about this front and center on the product page.
That’s really useful feedback — thank you. The picamera2 manual is actually the official Raspberry Pi documentation and it does cover a lot of the library’s architecture, including how it maps tuning files to camera sensors. For anyone else reading this: if your Arducam isn’t playing nice with picamera2, the issue is often that the default tuning file doesn’t match your sensor module, and understanding the mechanism described in that PDF is the right path.
I’m going to pass this along internally — having a more visible guide on our site that walks through the picamera2 setup for our modules, including tuning file selection, would definitely help. Thanks for flagging it, and glad you’re up and running now.
