Arducam B0520 for a nest box
I am planning to buy the Arducam B0520 (2MP USB camera module with the M12 pinhole lens) to monitor birds inside a nest box. I need to replace the original lens with a wider-angle one with as little distortion as possible (about 110° horizontal FOV would be ideal). The scene will be at a distance of roughly 10–30 cm from the camera, and the box is dark, so I plan to use IR illumination. Before ordering, I have a few questions:
  1. Can the Arducam LN013 (M27280M07S) be used on the B0520 and focused to a sharp image across 10–30 cm? Is the lens holder on the B0520 compatible with this lens (holder height / back focal length), or does it need a shorter one?
  2. The same question for the Arducam LN055 (M27195H15). Also, could you tell me its TV distortion value, which I could not find in the specification?
  3. According to the photos, the IR filter in these lenses looks like a separate element. Can the user remove it (for LN013 and for LN055), and if so, how? Does LN055 have an IR filter at all?
  4. Does the B0520 have any other IR-cut filter (on the sensor or in the holder), apart from the one in the lens, so that after removing the lens filter the camera becomes IR-sensitive?
  5. Are there a NoIR version of the B0520 or a recommended M12 lens without an IR filter, with a horizontal FOV of about 100–120° and low distortion?
Best regards,
Tomek
