Hey everyone, I’m having trouble getting my Arducam USB 3.0 16MP IMX519 (model B0471) to run at USB 3.0 speeds on a Jetson Orin Nano with Ubuntu 22.04. The camera works but only at USB 2.0 speeds — I’m capped around 10 fps at 720p, which is way below what it should do.
Looking at dmesg I’m seeing this:
[ 1234.567] usb 2-1: new high-speed USB device number 5 using tegra-xusb
The USB ID is 04b4:0471. It just won’t enumerate as SuperSpeed no matter what I try. Anyone run into this before?
That’s a bit odd — could you run lsusb -t and paste the output? That’ll show us exactly which speed tier the device is negotiating at. Also, are you using the cable that came with the camera or a third-party one?
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/4p, 10000M
|__ Port 1: Dev 5, If 0, Class=Vendor Specific Class, Driver=, 480M
So it’s definitely stuck at 480M (high-speed). I’ve gone ahead and tested the camera on every USB port on the Orin Nano — both the Type-A and Type-C ports — and the result is exactly the same across all of them. Always enumerates as USB 2.0.
I’m using the cable that shipped with the camera. Is there a firmware update I should be looking at? I’ve seen mentions of an FX3 firmware image (.img file) floating around for these cameras. If that’s the play, could someone point me to a Linux-compatible flashing utility too? I’m not running Windows on this setup.
Thanks for confirming. Based on what you’re seeing, this looks like a USB 3.0 link training / handshake failure between the B0471 camera and the Jetson Orin Nano host. The camera is falling back to USB 2.0 High-Speed mode instead of successfully negotiating SuperSpeed.
There are a few things that can cause this — driver quirks on the host side, firmware state on the FX3, cable signal integrity, or even specific port controller compatibility on the Jetson platform.
Before we jump straight to a firmware reflash, I’d strongly recommend working through the troubleshooting steps here first:
That’s section “2. Camera detected as USB 2.0 / UVC 2.0 instead of USB 3.0 / UVC 3.0” — it covers several things to check before going the firmware route. Give those a shot and let me know how it goes.
Alright, fair enough — I’ll go through those steps and report back. But just so I’m prepared: if the troubleshooting doc doesn’t get me anywhere, can you send over the correct FX3 firmware .img for the B0471 IMX519 and whatever tool I’d need to flash it from Linux? I want to have all my options lined up.
Absolutely. If the troubleshooting steps don’t resolve the SuperSpeed enumeration issue, I’ll provide the FX3 firmware image and the Linux flashing utility through private message. Just update this thread with your findings after working through that guide, and we’ll take it from there.
