I’m having a strange issue with my ARDUCAM B0459 USB camera. It works perfectly on one Jetson Nano — I get all resolutions including 1080p and even 4K. But on a second Jetson Nano, the same camera only shows 720p as an option. I’m using the exact same camera and the same USB 3.0 10Gbps cable on both devices. I’ve attached a photo of the setup. Has anyone seen this before? Why would the same hardware behave differently on two identical boards?
Since the camera works fully on your first Jetson Nano, the camera hardware itself is fine. The symptom you’re describing — missing resolutions above 720p — strongly suggests the camera is falling back to USB 2.0 mode on the problematic board. USB 2.0 simply doesn’t have enough bandwidth for uncompressed 1080p or higher, so those resolutions get dropped from the available format list.
Let’s verify this. Can you run the following command on the problematic Jetson Nano and post the output?
lsusb -t
This will show us which USB bus the camera is on and at what speed it’s connected.
Here’s the output from lsusb -t on the problematic Jetson Nano:
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/4p, 5000M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/5p, 480M
|__ Port 2: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 1: Dev 3, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 2: Dev 4, If 0, Class=Audio, Driver=snd-usb-audio, 12M
|__ Port 2: Dev 4, If 3, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 4, If 1, Class=Audio, Driver=snd-usb-audio, 12M
|__ Port 4: Dev 5, If 1, Class=Video, Driver=uvcvideo, 480M
|__ Port 4: Dev 5, If 0, Class=Video, Driver=uvcvideo, 480M
I can see the camera there as Dev 5 with uvcvideo, but I’m not sure how to interpret the rest.
This confirms the issue. Look at where your camera landed:
- Your camera (Dev 5,
uvcvideo) is on Bus 01 at 480M — that’s USB 2.0 High Speed. - Bus 02 is running at 5000M (USB 3.0 SuperSpeed) but the camera isn’t on it.
So the camera has failed to negotiate a USB 3.0 link on this board and fell back to USB 2.0 mode. That explains why you’re only seeing 720p.
Next, let’s see exactly what resolutions are being advertised by the camera in this state. Run this on the problematic device:
v4l2-ctl --device=/dev/video0 --list-formats-ext
Here’s what I get on the problematic Jetson Nano:
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'YUYV'
Interval: Discrete 0.100s (10.000 fps)
Only one resolution — 1280x720 at 10fps. That’s pretty limited. For comparison I also ran the same command on the working Jetson Nano. Here’s that output:
Index : 0
Interval: Discrete 0.008s (120.000 fps)
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.067s (15.000 fps)
Interval: Discrete 0.200s (5.000 fps)
Size: Discrete 1920x1080
Size: Discrete 2016x1520
Interval: Discrete 0.020s (50.000 fps)
Size: Discrete 3840x2160
Interval: Discrete 0.050s (20.000 fps)
Size: Discrete 4056x3040
Night and day difference. The working one shows everything from 720p all the way up to 4056x3040.
That’s exactly what I’d expect with a USB 2.0 vs USB 3.0 connection. Here’s a summary of what’s happening:
Root cause: The camera on your problematic Jetson Nano is not negotiating a USB 3.0 SuperSpeed (5000M) link. It’s falling back to USB 2.0 High Speed (480M). USB 2.0 can’t push uncompressed 1080p frames, so the system strips all resolutions above 720p from the format list. The lsusb -t output already proved the camera is on the 480M bus, and the v4l2-ctl output confirms the consequence — only 720p at 10fps is available.
On the working Jetson Nano, the camera successfully connects at USB 3.0 speeds and all resolutions (up to 4056x3040) are properly enumerated.
Next steps: I’d recommend following step #2 in our UVC camera troubleshooting guide here:
https://docs.arducam.com/UVC-Camera/Troubleshooting/#issue-description_1
That section walks through verifying the USB speed with lsusb and systematically troubleshooting why the USB 3.0 link isn’t coming up — things like trying different ports, checking power delivery, inspecting the port physically, and looking at any driver/kernel differences between the two boards. Even though you’re using the same USB 3.0 10Gbps cable on both, it’s worth re-seating connections and trying a different USB 3.0 port on the problematic board to rule out a flaky physical connection.
Thanks for the thorough breakdown. That makes complete sense now — the USB 2.0 fallback explains everything. I’ll go through the troubleshooting guide, especially step #2, and see if I can get the camera to negotiate a proper USB 3.0 link on this board. I’ll report back with what I find.
