Arducam B0332 120fps camera only reaches 70-100fps on Windows, not advertised fps
Hey all, I’ve got an Arducam B0332 USB camera (the 120fps global shutter 1MP 720p OV9281 UVC module with the M12 lens) on Windows. The listing says 120fps but I’m only getting around 80fps in the apps I’ve tried so far. Is there a Windows setting I need to change to unlock the full frame rate, or is something else going on?
Hi, the capture app matters a lot for these UVC boards. Default Windows camera apps tend to top out lower. Try Amcap.exe — with that you should get closer to 100fps. I’ve sent you the Amcap download link in a private message, so check your messages and give it a shot.
Thanks, got the link. I ran Amcap and now I’m seeing around 100fps, which is definitely better than the 70-80fps I was getting before. But it’s still short of the advertised 120fps. Is that expected, or am I still missing something?
Glad it improved. To be clear, the full 120fps isn’t achievable in every capture program — the frame rate you can actually pull depends a lot on the software. That’s why Amcap gets you to ~100fps while most other programs stay around 70-80fps. It’s not a Windows setting; it’s which capture app you use.
Got it, but honestly I picked this camera specifically because of the 120fps spec. If it only reaches 100fps with one specific program and 70-80fps everywhere else, then why is it listed as 120fps in the first place?
You’re right, and that one’s on us — the product page wasn’t updated in time. We’ve also confirmed the camera can reach 100fps in Potplayer, so that’s another option for capture. I’ve sent you the Potplayer download details in a private message as well.
Okay, so just to be sure I understand — there’s no way to actually hit 120fps with this camera, and 100fps in Potplayer (or Amcap) is the realistic maximum?
Correct. To wrap up: the 120fps figure was a documentation/product page issue. The realistic achievable frame rate is around 100fps when using Potplayer (or Amcap), and 70-80fps in other software. There isn’t a setting or capture tweak that will get you to 120fps — 100fps is what this board will actually do.
