Hi, I have a few questions about the Arducam B0280 USB camera (UVC webcam series). I’m using it on a Windows PC and working with Python.
When I set the resolution lower, the exposure values come out really high. Like the image gets way too bright. Is there a fix?
How can I lower the FPS value if I’m controlling the camera from Python? I keep looking for a way to set it but nothing seems to stick.
Can this type of camera be used in an industrial environment?
I don’t have any code yet, I was hoping someone could give me an example Python command, or point me to a Python library/package that supports this camera. Thanks.
Hi, thanks for the detailed post. Bin here from the Arducam support team.
Let me go through your three points:
High exposure at lower resolution - this looks like it could be firmware-related. To check if it’s something we can fix on our side, I need to know exactly which camera you’re using. The B0280 name helps but I want to be sure of the exact model before looking at firmware.
Lowering FPS from Python - the sensor on this camera runs at a fixed frame rate. That means you can’t change it from software/Python. Multi-framerate support only comes from a custom order, so for that you’d need to get in touch with our sales team.
Industrial use - yes, of course it can be used in an industrial environment.
So for point 1, please tell me which camera you are using. Maybe I can help you fix the firmware.
Ok the camera is the Arducam B0280, that’s the one I have. USB camera.
So just to confirm what you said - the sensor is fixed frame rate and I can’t change the FPS with Python at all? Even with a library? And for multi framerate I have to contact sales for a custom order, right?
Got it. Recently, I will try to optimize the image quality of this camera.
So to sum up where we are on the three points:
High exposure values at lower resolution on the B0280: this is something that has to be improved/optimized on our side, so there’s no ready-made patch I can hand you right now. I’ll be working on optimizing the image quality for this camera, and once that’s done it should address the exposure behavior you’re seeing.
FPS: the sensor is fixed frame rate, so it can’t be lowered from Python. If you need multi-framerate, that requires a custom order through our sales team.
Industrial use: yes, the B0280 can be used in an industrial environment.
