Arducam B006604 camera module not working properly
Hi, I’m having trouble with an Arducam B006604 camera module and I can’t figure out what’s wrong. I recorded two videos to show the issue:
Working setup (different camera module):
workimg arducam model.mp4
The B006604 that’s giving me trouble:
not-working arducam model B006604.mp4
Same setup works with the other module, but the B006604 just won’t cooperate. Any ideas where I should start?
Thanks for the videos — the side-by-side comparison is really useful. I can see the difference, but I need to know what the Pi is actually reporting before I can pin down the cause. Can you generate a bug report?
Steps:
  1. Reboot your device.
  2. Download the bug report tool:
  1. Make it executable:
  1. Run it:
  1. That creates arducam-bug-report.txt in the current directory. Attach the file here and I’ll take a look.
Thanks, I ran through those steps and the tool produced the report. Attaching it here:
Thanks for the report. There’s a conflict though. The bug report shows the Pi doesn’t detect the camera module, but in your video the camera clearly gets recognized. Those two results don’t match.
The most likely explanation is that the camera wasn’t connected to the Pi while you ran the bug report steps. Can you confirm the B006604 was physically connected to the Pi Zero when you ran the tool? If you’re not sure, please re-run it with the camera definitely connected and attach the new report.
Just to lay out my setup:
  • Raspberry Pi Zero 2 W
  • Arducam B006604 (the non-working module)
  • Arducam B0033 (working module, for comparison)
I followed the steps exactly and the B006604 was connected to the Pi Zero 2 W when I ran the bug report tool. I also tested both modules side by side and recorded a video of both — the B0033 works fine but the B006604 still doesn’t. Photos for reference:
B0033 working
B006604 not working
Thanks for the photos and for confirming the connection. So as it stands: the B006604 is connected to the Pi Zero 2 W, but the bug report still shows no camera detected, while the B0033 works in the same setup. That’s still at odds with your original video, so we’re digging into the report and the photos further. I’ll follow up here once we’ve got more.
