Kamami
b0245
Raspberry Pi CM4 with IO board
https://www.arducam.com/docs/arducam-obisp-mipi-camera-module/3-use-on-raspberry-pi/3-0-emergent-temporary-driver-for-the-lastest-rpi-2020-12-02-update/
It worked with Raspberry Pi 4b+
I followed the guide, connected the camera via 22-to-15-pin connector to CAM1 and it still isn’t visible at ls /dev/vid*.
Tried downgrading kernel and using the v1.0 driver and nothing. Tried official raspi camera - worked.
Turned out that removing the dtoverlay=dwc2,dr_mode=host line (which enables the usb 2.0 ports) from /boot/config.txt made the connection appear. So the question now is, is it possible to have both the usb 2.0 and the camera work?
