Arducam AR0234 camera MIPI connector mismatch with Jetson AGX Orin adapter
Hey everyone, I recently purchased an Arducam 2.3MP AR0234 global shutter camera (the presale version for Jetson Nano/NX), but I actually need to connect it to a Jetson AGX Orin Dev Kit. I also bought an Allied Vision adapter board from DigiKey (ADAPTER BOARD AGX ORIN DEV KIT), but the MIPI connectors don’t match up at all. Is there a known adapter that can bridge this? I saw the Arducam IMX219 multi-camera kit for Jetson AGX Orin (https://www.arducam.com/arducam-imx219-multi-camera-kit-for-the-nvidia-jetson-agx-orin.html) — would that work as an adapter? Or could I just swap out the ribbon cable on the AR0234 module for one that fits my existing adapter?
Let me break this down. The physical MIPI connectors on the AR0234 camera module and the Jetson AGX Orin Development Kit are completely different — that’s why the Allied Vision adapter doesn’t fit. The AR0234 module uses a standard 22-pin MIPI CSI-2 FPC connector, while the Jetson AGX Orin has a high-density connector. Different adapters have different pinouts and electrical characteristics, so you can’t just swap ribbon cables between incompatible boards.
Do NOT try to use the Allied Vision adapter board with a different ribbon cable — that could damage either the camera or the Orin itself. The correct approach is to buy the specific Arducam adapter board from that IMX219 Multi-Camera Kit you linked. That adapter board converts the Jetson AGX Orin’s high-density camera connector into standard 15-pin MIPI CSI-2 FPC connectors, which are physically compatible with your AR0234 module. Use the official Arducam adapter for a stable, tested connection.
Thanks for the clarification. So if I get that adapter board, and let’s say I use a camera from the Jetvariety project line connected to it — should that be compatible with the Jetson AGX Orin out of the box? Also, can I connect multiple cameras simultaneously to that adapter board? I have two cameras I’m concerned about: 1) Arducam 2.3MP AR0234 global shutter color B0368 (https://www.arducam.com/arducam-2-3mp-ar0234-global-shutter-color-b0368.html) and 2) a 1.58MP IMX296 color global shutter camera module for DepthAI OAK (https://www.arducam.com/1-58mp-imx296-color-global-shutter-camera-module-for-depthai-oak.html). Would either or both work on this adapter board? And what about using a third-party MIPI camera with its own adapter and driver — can I run that through the Arducam board using the third-party’s driver?
Great questions. Here’s the deal:
For Jetvariety cameras on the adapter board: Yes, if you choose a camera from the Jetvariety line and connect it to the adapter board, it will be compatible with the Jetson AGX Orin after you install the appropriate Arducam driver for that camera. The adapter board solves the physical connection; the driver solves the configuration.
Multiple cameras: Yes, multiple cameras can be physically connected to the adapter board simultaneously and run concurrently. However, the adapter board does NOT provide hardware-level frame synchronization — so no guarantee frames are captured at the exact same microsecond.
Those two specific cameras: The AR0234 B0368 and the IMX296 are designed for the OAK Depth Kit and are incompatible with this adapter board. As for third-party MIPI cameras with their own drivers — that won’t work reliably. Here’s why: a third-party camera driver is written assuming direct connection to the NVIDIA dev kit’s CSI port, expecting specific I2C bus addresses, power regulators, and GPIO pin configurations. The Arducam adapter board has its own electronics that alter these paths, so the third-party driver would fail to initialize the camera correctly. Only Arducam’s own Jetvariety cameras are supported with the adapter boards and drivers.
Okay, I think I understand now. I realize I bought the wrong camera models for my needs. After going through the Jetvariety documentation, I’ve identified two cameras that might actually work:
  1. B0429 — Arducam 2.3MP AR0234 global shutter camera for Nvidia Jetson Nano/NX (https://www.arducam.com/presale-arducam-2-3mp-ar0234-global-shutter-camera-for-nvidia-jetson-nano-nx.html)
  2. B0586 — Arducam 4K HDR high framerate MIPI camera with onboard ISP for Nvidia Jetson Orin Nano/NX (https://www.arducam.com/arducam-4k-hdr-high-framerate-mipi-camera-with-onboard-isp-for-nvidia-jetson-orin-nano-nx.html)
Can you confirm both of these are compatible with the Jetson AGX Orin using the adapter board? Also, where do I download the required drivers for these? And is it possible to return my original cameras (B0368 and B0456) so I can purchase instead: 1 adapter board, 1 unit of B0429, and 1 unit of B0586?
Compatibility confirmed: Only B0429 is the Jetvariety camera and will work with the Jetson AGX Orin when used with the Arducam adapter board from the IMX219 Multi-Camera Kit. The setup is straightforward:
  1. Connect the camera to the adapter board
  2. Connect the adapter board to the Jetson AGX Orin
  3. Install the appropriate Arducam driver for each camera (drivers are available on Arducam’s GitHub or support page — check the product pages for direct download links)
Just remember: do NOT attempt to use third-party cameras or drivers with the Arducam adapter board — incompatible connections risk damaging the camera module or the Jetson Orin itself. Stick with Jetvariety cameras and Arducam’s official drivers for a stable, tested setup.
