Arducam 8MP USB camera not detected on Chromebook when plugged in
I just picked up an Arducam 8MP 1080P Auto Focus USB Camera Module for Computer with Metal Case, 1/3.2" IMX179 Lightburn Camera USB2.0 Webcam Board with Microphone (listed for Windows, Linux, Android and Mac OS). When I plug the USB cable in, nothing happens at all. Will this camera work on a Chromebook? And if so, what software do I need?
Small update: I figured out how to turn it on and it will record now. Separate question - does this camera have any motion detection capability?
To be honest, we haven’t used Chromebook/Chrome OS before, so I’m concerned this camera may not work on a Chromebook. I don’t have a confirmed Chromebook solution at the moment.
On motion detection: this camera uses a rolling shutter sensor. Rolling shutter scans the image vertically from top to bottom, so different parts of the frame are exposed at slightly different times. That introduces a “rolling shutter effect” and motion blur with moving objects. A global shutter camera exposes the entire sensor at once, so it captures the position and shape of fast-moving objects accurately. If you need precise motion detection, especially for fast-moving objects, a global shutter camera is the better choice.
Thanks. Chrome OS can actually run Linux commands, so is there a Linux command I can use to make Linux recognize the camera?
This is a USB camera (UVC-style), so it does not need an extra camera driver. When you connect it, the OS should detect it automatically - you shouldn’t need to install anything to make Linux recognize it.
To verify it’s been detected on Linux, run:
ls /dev/video0
If the device node shows up in the output, Linux sees the camera. So just connect the camera to the Chromebook and check for /dev/video0.
