Arducam 64MP not working at RPi4/RPi5
I have several Arducam 64MP Hawkeye camera modules from the Kickstarter campain.
I never came to use them. But now i tryed:
I started with a fresh installed sd card and followed the instructions on this site: 64MP Hawkeye - Arducam Wiki
On an RPi4 and RPi5 i get the following error:
[0:01:14.843012767] [1809]  INFO Camera camera_manager.cpp:326 libcamera v0.5.0+84-79f583c3-dirty (2025-05-06T02:52:19BST)
[0:01:14.850329284] [1827]  INFO RPI pisp.cpp:720 libpisp version v1.2.1 981977ff21f3 29-04-2025 (14:13:50)
[0:01:14.868131826] [1827]  INFO RPI pisp.cpp:1180 Registered camera /base/axi/pcie@1000120000/rp1/i2c@80000/arducam_64mp@1a to CFE device /dev/media0 and ISP device /dev/media1 using PiSP variant BCM2712_C0
Mode selection for 4624:3472:12:P
    SRGGB10_CSI2P,1280x720/0 - Score: 13359.2
    SRGGB10_CSI2P,1920x1080/0 - Score: 11359.2
    SRGGB10_CSI2P,2312x1736/0 - Score: 9096
    SRGGB10_CSI2P,3840x2160/0 - Score: 5359.24
    SRGGB10_CSI2P,4624x3472/0 - Score: 1000
    SRGGB10_CSI2P,8000x6000/0 - Score: 2476.58
    SRGGB10_CSI2P,9152x6944/0 - Score: 3041.47
Stream configuration adjusted
[0:01:14.868831292] [1809]  INFO Camera camera.cpp:1205 configuring streams: (0) 4624x3472-YUV420 (1) 4624x3472-RGGB_PISP_COMP1
[0:01:14.868930052] [1827]  INFO RPI pisp.cpp:1484 Sensor: /base/axi/pcie@1000120000/rp1/i2c@80000/arducam_64mp@1a - Selected sensor format: 4624x3472-SRGGB10_1X10 - Selected CFE format: 4624x3472-PC1R
[0:01:14.989700193] [1827] ERROR V4L2 v4l2_videodevice.cpp:2049 /dev/video1[20:cap]: Failed to start streaming: Input/output error
Also i can see the following:
dmesg | grep 64mp
[    0.060983] /axi/pcie@1000120000/rp1/i2c@80000/arducam_64mp@1a: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@128000
[    0.061008] /axi/pcie@1000120000/rp1/csi@128000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@80000/arducam_64mp@1a
[    0.061119] /axi/pcie@1000120000/rp1/i2c@80000/arducam_64mp@1a: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@128000
[    0.061143] /axi/pcie@1000120000/rp1/csi@128000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@80000/arducam_64mp@1a
[    0.442065] /axi/pcie@1000120000/rp1/i2c@80000/arducam_64mp@1a: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@128000
[    0.457176] /axi/pcie@1000120000/rp1/i2c@80000/arducam_64mp@1a: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@128000
[    0.457194] /axi/pcie@1000120000/rp1/csi@128000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@80000/arducam_64mp@1a
[    1.885876] rp1-cfe 1f00128000.csi: found subdevice /axi/pcie@1000120000/rp1/i2c@80000/arducam_64mp@1a
[    2.032176] arducam_64mp 11-001a: Device found Arducam 64MP.
[    2.035500] rp1-cfe 1f00128000.csi: Using sensor arducam_64mp 11-001a for capture
[   74.745498] arducam_64mp 11-001a: Failed to write reg 0x0100. error = -5
[   74.745504] arducam_64mp 11-001a: arducam_64mp_start_streaming failed to set common settings
does someone has an idea what the problem could be?
To help us troubleshoot, could you please confirm if this issue occurs with all the 64MP camera modules you have?
Than you for your reply. I just tested all modules, and i can confirm that i see this error with every single one. I don’t know if this matters, but the modules are marked with red dots.
I want to know the output of the command dpkg -l | grep libcamera. Could you post it here?
Sorry for the long wait. Here is the output of dpkg -l | grep libcamera:
ii  libcamera-dev:arm64                  0.5.0+rpt20250506-4              arm64        complex camera support library (development files)
ii  libcamera-ipa:arm64                  0.5.0+rpt20250506-4              arm64        complex camera support library (IPA modules)
ii  libcamera0.5:arm64                   0.5.0+rpt20250506-4              arm64        complex camera support library
ii  python3-libcamera:arm64              0.5.0+rpt20250429-1              arm64        complex camera support library (Python bindings)
Okay, so i found also working camera modules:
The date(?) code on the connector for the working modules are:
M1304, M1304, M1318
And for the not working modules:
M1227, M1228, M1228, M1619
But i think the real reason is a manufacturing error, because the population of an resistor correlates with working/not working modules:
Is there an schematic available? Could you confirm my suspicion?
Hi @zeflo
Bingo. We’ve located the problem. Please note that if the resistor is populated like below, this camera module is designed specially for the Camarray HAT Kit. It will not send the clock signal to the Raspberry Pi. Hence, you cannot use the libcamera command to display preview screen when this camera connected to the Pi directly.
Did you also purchase this Kit?
Thanks a lot for the explanation. I wasn’t aware of these modifications. I think i purchased also a kit. Could you tell me what the value of these resistors are and if this is the only modification? Is it possible to switch the camera “type” just by moving the resistor?
It should be 0Ω. Yes, if you swap the resistor, you should get these four cameras to work as expected.
Perfect! Thank you for your help!
