Arducam 64MP Eagle Eye camera not recognized on Raspberry Pi 5 after OS upgrades
Hey everyone, hoping someone can point me in the right direction. I’ve got an Arducam 64MP Eagle Eye camera (shows up as arducam_64mp) on a Raspberry Pi 5, and after a few OS upgrades it’s no longer detected at all. It worked fine before the upgrades — I ran it several times without any issues. Now libcamera-still just ends with ‘no cameras available’. I’m currently on libcamera v0.3.1+50-69a894c4 and libpisp v1.0.7 28196ed6edcf. Any idea what changed?
Can you run the failing capture command and paste the full terminal output? Something like:
libcamera-still -t 5000
The log lines right before the error should tell us whether it’s a sensor detection problem or something to do with the IPA / camera helper loading.
Sure, here’s the output from libcamera-still -t 5000:
[0:04:50.866744383] [2103] INFO Camera camera_manager.cpp:316 libcamera v0.3.1+50-69a894c4
[0:04:50.878896992] [2109] INFO RPI pisp.cpp:695 libpisp version v1.0.7 28196ed6edcf 29-08-2024 (16:33:32)
[0:04:50.879827703] [2109] WARN CameraSensorProperties camera_sensor_properties.cpp:295 No static properties available for ‘arducam_64mp’
[0:04:50.879839166] [2109] WARN CameraSensorProperties camera_sensor_properties.cpp:297 Please consider updating the camera sensor properties database
[0:04:50.891171441] [2109] ERROR IPAProxy ipa_proxy.cpp:155 Configuration file ‘arducam_64mp.json’ not found for IPA module ‘rpi/pisp’
[0:04:50.891229592] [2109] ERROR IPARPI ipa_base.cpp:126 Could not create camera helper for arducam_64mp
[0:04:50.891237574] [2109] ERROR RPI pipeline_base.cpp:819 Failed to load a suitable IPA library
[0:04:50.891243500] [2109] ERROR RPI pisp.cpp:922 Failed to register camera arducam_64mp 6-001a: -22
Made X/EGL preview window
It gets as far as the camera manager and then fails right when it tries to register arducam_64mp.
Thanks, that output is pretty clear. A few things are happening here:
  • ‘No static properties available for arducam_64mp’ and ‘Please consider updating the camera sensor properties database’ — libcamera doesn’t have the sensor properties for this camera.
  • ‘Configuration file arducam_64mp.json not found for IPA module rpi/pisp’ — the rpi/pisp IPA can’t find its tuning/helper config for this sensor.
  • ‘Could not create camera helper for arducam_64mp’ and ‘Failed to load a suitable IPA library’ — because the helper can’t be created, the IPA fails to load.
  • ‘Failed to register camera arducam_64mp 6-001a: -22’ — registration then fails, which is why you end up with ‘no cameras available’.
So this isn’t a wiring or hardware detection issue. The camera is being enumerated, but libcamera can’t load the Arducam-specific support files it needs for the Pi 5’s pisp pipeline.
That matches what I’m seeing. So is the Arducam libcamera install just too old for the current Pi 5 OS? I’m guessing the OS upgrades replaced or moved the files the camera helper depends on. What’s the cleanest way to fix it?
Right — after the Pi 5 OS upgrades, the Arducam libcamera installation is outdated/incompatible. libcamera can’t load the arducam_64mp.json IPA config for the rpi/pisp module, so it can’t create the camera helper, and registration fails with that -22 error. Arducam has since updated their libcamera build for this. Update the Arducam libcamera using the steps in this post:
Reinstalling/updating the Arducam-specific libcamera package restores the missing arducam_64mp sensor properties and IPA helper files so the camera registers correctly on the Pi 5.
Thanks, that worked. I followed the update steps and the camera is detected again — libcamera-still now registers arducam_64mp without the IPA errors. Appreciate the help!
