I’ve been fighting with this for a couple of days and I’m stuck. I picked up an Arducam 64MP Hawkeye camera and it’s just not operational no matter what I try.
My setup:
Raspberry Pi 4B (2018, 2GB)
Also tried a Pi Zero 2W
64GB SD card with a fresh Raspberry Pi OS install
Tried all 3 ribbon cables that came with the camera
Thanks for the report. Interesting — you originally had /dev/video0 showing up, but after the fresh install with update/upgrade plus the software guide path, nothing appears. That points more toward the software/install side than the hardware.
Can you try one more fresh install, but this time skip the update/upgrade and go straight to Jeff Geerling’s method?
Then reboot and check ls /dev/video* again. Also send the bug report from that state.
To sum it up: this looks like a software/installation issue rather than a hardware problem. The working path was a fresh Raspberry Pi OS 32-bit install followed by Jeff Geerling’s installation method, and after reboot ls /dev/video* detected the camera.
For reference, the earlier attempt (fresh 32-bit install → update/upgrade → SOFTWARE GUIDE for 64MP Camera → reboot) left no camera on /dev/video*, even after repeating it twice. So either the update/upgrade or the install method was the difference — hard to say which, but the Jeff Geerling route is the one that came up working.
