Hi everyone, my Arducam 64MP camera has suddenly stopped working on my Raspberry Pi 5. When I try to launch the camera it fails before streaming starts:
/dev/video1[20:cap]: Failed to start streaming: Input/output error
It worked fine before and then just quit. I’ve already searched around and tried a few things I found online but none of them helped.
The sensor is detected: arducam_64mp registered at /base/axi/pcie@120000/rp1/i2c@80000/arducam_64mp@1a, CFE device /dev/media3, ISP device /dev/media0.
I already searched for this error and tried the common fixes I found, but they didn’t help. It worked before and then quit working.
Thanks, that helps. The sensor being registered but streaming failing usually means the driver can see it but something breaks when V4L2 tries to pull frames. Can you run the Arducam bug report tool and paste the output here?
./arducam-camera-bug-report
That should dump the libcamera/streaming log so we can see exactly where it fails.
I ran it. Here’s the output (screenshot attached too):
[0:03:34.113909303] [2294] INFO Camera camera_manager.cpp:325 libcamera v0.3.2+124-e0a2304e-dirty (2024-12-09T06:48:46GMT)
[0:03:34.121737192] [2297] INFO RPI pisp.cpp:695 libpisp version v1.0.7 28196ed6edcf 29-08-2024 (16:33:32)
[0:03:34.122663608] [2297] WARN CameraSensorProperties camera_sensor_properties.cpp:305 No static properties available for ‘arducam_64mp’
[0:03:34.122672960] [2297] WARN CameraSensorProperties camera_sensor_properties.cpp:307 Please consider updating the camera sensor properties database
[0:03:34.140141384] [2297] INFO RPI pisp.cpp:1155 Registered camera /base/axi/pcie@120000/rp1/i2c@80000/arducam_64mp@1a to CFE device /dev/media3 and ISP device /dev/media0 using PiSP variant BCM2712_C0
Mode selection for 4624:2600:12:P
SRGGB10_CSI2P,1280x720/0 - Score: 11450.1
SRGGB10_CSI2P,1920x1080/0 - Score: 9450.05
SRGGB10_CSI2P,2312x1736/0 - Score: 8691.99
SRGGB10_CSI2P,3840x2160/0 - Score: 3450.05
SRGGB10_CSI2P,4624x3472/0 - Score: 2557.99
SRGGB10_CSI2P,8000x6000/0 - Score: 4029.38
SRGGB10_CSI2P,9152x6944/0 - Score: 4599.47
Stream configuration adjusted
[0:03:34.140873058] [2294] INFO Camera camera.cpp:1197 configuring streams: (0) 4624x2600-YUV420 (1) 4624x3472-RGGB_PISP_COMP1
[0:03:34.140956651] [2297] INFO RPI pisp.cpp:1451 Sensor: /base/axi/pcie@120000/rp1/i2c@80000/arducam_64mp@1a - Selected sensor format: 4624x3472-SRGGB10_1X10 - Selected CFE format: 4624x3472-PC1R
[0:03:34.230170198] [2297] ERROR V4L2 v4l2_videodevice.cpp:2026 /dev/video1[20:cap]: Failed to start streaming: Input/output error
[0:03:40.140018895] [1813] ERROR V4L2 v4l2_videodevice.cpp:2026 /dev/video1[20:cap]: Failed to start streaming: Input/output error
Looking at that log, the camera is detected and registered to CFE /dev/media3 and ISP /dev/media0, but it fails at the V4L2 layer on /dev/video1 with an Input/output error. Since it worked before and then stopped, that points more toward a sensor communication or hardware connection problem than a pure software config issue, though I can’t confirm the root cause yet from the log alone.
Can you PM me a couple of photos of the hardware connection at both the Raspberry Pi end and the camera end of the cable? Also, the tool should have created arducam-bug-report.txt in the current directory. Please send that file over private message too so I can review the full report.
Will do, I’ll grab photos of both ends and send the txt file in a bit. Is there anything I should try in the meantime? I already rebooted once earlier, but I can do it again if that helps.
Make it executable:
Run it:
That writes arducam-bug-report.txt in the current directory. Please send that file to me through private message.
To summarize what we know so far: even though the arducam_64mp sensor is detected and registered, streaming fails at the V4L2 layer with an Input/output error. That pattern usually points to a physical connection/cable/power issue or sensor communication failure rather than a pure driver misconfiguration. The WARN lines about missing static properties for ‘arducam_64mp’ also suggest the camera sensor properties database should be updated, but those warnings alone probably aren’t what’s stopping the stream. Let’s see what the photos and the fresh bug report show.
