Hi all, my Arducam 64MP autofocus camera on a Raspberry Pi 5 (8GB) has stopped working. It used to launch fine, but now when I try to start it I get:
/dev/video1[20:cap]: Failed to start streaming: Input/output error
I haven’t changed anything obvious. Anyone seen this before?
Hey, sorry you’re hitting that. Can you share a bit more about the setup? Which camera SKU and Pi model, what libcamera/libpisp versions you’re running, and which guide you followed? Also, have you tried running the Arducam bug report tool?
Sure. It’s a Raspberry Pi 5 8GB with the 64MP PDAF&CDAF Autofocus Camera, SKU B0399. I followed the Hawkeye native camera guide:
https://docs.arducam.com/Raspberry-Pi-Camera/Native-camera/64MP-Hawkeye/
Versions:
libcamera v0.3.2+124-e0a2304e-dirty (2024-12-09T06:48:46GMT)
libpisp version v1.0.7 28196ed6edcf 29-08-2024 (16:33:32)
Camera sensor: ‘arducam_64mp’
Sensor path: /base/axi/pcie@120000/rp1/i2c@80000/arducam_64mp@1a
CFE device /dev/media3, ISP device /dev/media0, PiSP variant BCM2712_C0
I also ran ./arducam-camera-bug-report.
Thanks. Can you paste the relevant output from the bug report tool? The mode selection block and the exact failure point are the most useful.
Here’s the output:
[0:03:34.113909303] [2294] INFO Camera camera_manager.cpp:325 libcamera v0.3.2+124-e0a2304e-dirty (2024-12-09T06:48:46GMT)
[0:03:34.121737192] [2297] INFO RPI pisp.cpp:695 libpisp version v1.0.7 28196ed6edcf 29-08-2024 (16:33:32)
[0:03:34.122663608] [2297] WARN CameraSensorProperties camera_sensor_properties.cpp:305 No static properties available for ‘arducam_64mp’
[0:03:34.122672960] [2297] WARN CameraSensorProperties camera_sensor_properties.cpp:307 Please consider updating the camera sensor properties database
[0:03:34.140141384] [2297] INFO RPI pisp.cpp:1155 Registered camera /base/axi/pcie@120000/rp1/i2c@80000/arducam_64mp@1a to CFE device /dev/media3 and ISP device /dev/media0 using PiSP variant BCM2712_C0
Mode selection for 4624:2600:12:P:
SRGGB10_CSI2P,1280x720/0 - Score: 11450.1
SRGGB10_CSI2P,1920x1080/0 - Score: 9450.05
SRGGB10_CSI2P,2312x1736/0 - Score: 8691.99
SRGGB10_CSI2P,3840x2160/0 - Score: 3450.05
SRGGB10_CSI2P,4624x3472/0 - Score: 2557.99
SRGGB10_CSI2P,8000x6000/0 - Score: 4029.38
SRGGB10_CSI2P,9152x6944/0 - Score: 4599.47
Stream configuration adjusted
[0:03:34.140873058] [2294] INFO Camera camera.cpp:1197 configuring streams: (0) 4624x2600-YUV420 (1) 4624x3472-RGGB_PISP_COMP1
[0:03:34.140956651] [2297] INFO RPI pisp.cpp:1451 Sensor: /base/axi/pcie@120000/rp1/i2c@80000/arducam_64mp@1a - Selected sensor format: 4624x3472-SRGGB10_1X10 - Selected CFE format: 4624x3472-PC1R
[0:03:34.230170198] [2297] ERROR V4L2 v4l2_videodevice.cpp:2026 /dev/video1[20:cap]: Failed to start streaming: Input/output error
Bug report generated to arducam-bug-report.txt
Thanks, that’s helpful. The important part is that the sensor is detected and registered correctly, but libcamera fails when it tries to start the stream on /dev/video1. The ‘No static properties available for arducam_64mp’ warning is usually just a missing database entry and probably isn’t the cause here. The I/O error on stream start is the real failure.
Can you try it once more to confirm it’s consistent? Also, have you tried reseating the ribbon cable on both ends?
I ran it again and got the same failure:
[0:03:40.140018895] [1813] ERROR V4L2 v4l2_videodevice.cpp:2026 /dev/video1[20:cap]: Failed to start streaming: Input/output error
I also searched online and tried a bunch of suggestions, but none of them helped. I’ve attached a screenshot of the error (image.png).
Thanks for retesting. We haven’t pinned down the root cause yet. Since detection works but stream start fails, we want to check the physical connection and get the full bug report.
Can you post pictures of both ends of the ribbon cable connection (Raspberry Pi side and camera module side)?
For the report, please do the following:
- Reboot your device.
- Download the bug report tool — I’ve sent you the link in a private message, please check your messages.
- Set executable permissions: chmod +x ./arducam-camera-bug-report
- Run it: ./arducam-camera-bug-report
It will produce arducam-bug-report.txt in the current directory. Please send that file to us for further analysis.
Okay, I rebooted and ran the tool again, and it generated arducam-bug-report.txt. I’ll send it over directly. I’ll also take photos of the cable connections at both ends. Anything specific I should look for on the connector?
To summarize where we are: the camera sensor is detected and registered (arducam_64mp at /base/axi/pcie@120000/rp1/i2c@80000/arducam_64mp@1a, CFE /dev/media3, ISP /dev/media0, PiSP variant BCM2712_C0), mode selection and stream configuration complete, but streaming fails at /dev/video1 with an Input/output error when V4L2 tries to start the stream. That means the failure is during stream start, not detection. The sensor-properties warnings are probably not the cause. Root cause is still open — we’re waiting on the bug report and connection photos. In the meantime, reseat the cable and try again after a full reboot.
