Arducam 64MP-AF not detected on OctoPrint Pi 3 B+, camera-bug-report not found
Hi, I’m trying to use the Arducam 64MP-AF camera module with OctoPrint on my Raspberry Pi 3 B+ and the camera just isn’t being recognized at all. I’ve double checked that all the connections are solid and in the correct orientation. I followed every step of the install instructions. Honestly it feels like the camera is defective, but before I assume that I wanted to ask here. I tried running the camera-bug-report tool to grab logs and my shell just says the command doesn’t exist, so I can’t even get a proper report out of it. Anyone know what I’m doing wrong?
Happy to help dig into this. A couple of quick things first - what OS image are you running on the Pi, and can you paste the output of these so we can see your setup?
cat /etc/os-release
uname -a
dpkg -l | grep libcamera
ls /dev/video*
Also, when you say camera-bug-report doesn’t exist, paste the exact command and the error you get. The OctoPrint hostname/user would help too so we know what environment we’re dealing with.
Sure. The host is an OctoPrint host, hostname octopi, I’m logging in as fernizzil@octopi on the Pi 3 B+.
Here’s what I ran and what I got:
fernizzil@octopi:~ $ dpkg -l | grep libcamera
fernizzil@octopi:~ $ camera-bug-report -t 5 -o bug.txt -c "libcamera-still -t 1000 -o test.jpg"
And the output:
ii  libcamera-apps                         0.0.2                               armhf        libcamera-apps
ii  libcamera-dev                          0.0.2                               armhf        libcamera
-bash: camera-bug-report: command not found
I ran the camera-bug-report line twice hoping to generate bug.txt but both times it just says command not found. So right now I have no bug report and the camera is not showing up anywhere.
Also, I did go back and follow the installation instructions again from scratch, and I verified the ribbon cable is fully seated and not flipped. Still nothing. Should I just assume it’s a bad module at this point?
Don’t assume the module is dead yet, there’s a pretty clear clue in what you pasted. “camera-bug-report: command not found” combined with libcamera-apps at only 0.0.2 tells me the OS underneath is likely the issue rather than the camera itself. That helper script ships with the supported image stack, so if it’s missing entirely, you’re probably not on the supported OS.
Can you also grab this so we can confirm:
cat /etc/os-release
And if you have any diagnostics you’ve already collected, attach them to the thread so I can look at the full picture.
OK, I collected the diagnostics and attached them here so you can see everything.
Problem: camera is not detected, and the diagnostics I gathered may help.
Attempts: I ran the diagnostics collection and attached the output.
Attachment: Diagnostics for 64mp.txt
Thanks, that attachment confirms it. Your diagnostics show:
Root cause: you’re running the Buster (Raspberry Pi OS) release, and Buster is NOT a supported OS for the 64MP camera setup. That’s why the camera isn’t coming up and why the tooling isn’t there - the missing camera-bug-report command is fully consistent with running an unsupported OS.
What to do: reflash with Bullseye (Raspberry Pi OS Full) instead of Buster. Grab it here:
https://downloads.raspberrypi.org/raspios_full_armhf/images/raspios_full_armhf-2022-04-07/
Use that full armhf image, reinstall your camera software on the fresh system, and then re-run the detection. Let me know what you see.
Okay I switched systems and installed a 64bit Raspbian Bullseye environment this time. Unfortunately the camera is STILL not detected. Same situation as before basically, it just doesn’t show up. I ran the diagnostics again and attached the result.
Attachment: diagnostic_64mp_6.30.2022
Heads up on one important detail before we go further: you installed the 64-bit Bullseye, but what’s required here is the 32-bit full armhf image - raspiOS_full_armhf-2022-04-07, the exact one I linked. The 64-bit build is a different beast and isn’t the supported target for this camera stack, so testing on it is going to give misleading results.
Can you double check what you flashed:
uname -m
dpkg --print-architecture
cat /etc/os-release
If it reports aarch64, please reflash the 32-bit full armhf Bullseye image and re-check detection. Go ahead and send the new diagnostic once you’re on the correct image and I’ll go through it. Right now I can’t call this fixed - the 64-bit image mismatch means we haven’t actually tested the supported configuration yet.
