Arducam 5MP Wide Angle USB cameras missing serial numbers for multi-camera detection
Hi all. I’m running a setup with several Arducam 5MP Wide Angle USB Cameras connected to the same computer, and I can’t reliably tell them apart. None of them include a serial number in the USB device ID, so when I plug in multiple units I can’t assign a specific camera to a specific task. I’m flexible on OS — I can use Windows, Linux, or Mac for whatever tool is needed. I found an old 2021 post on forum.arducam.com saying you could email Arducam for software that sets a unique serial number on each camera. Is that still the way to get it, or is there a download somewhere?
Hi, welcome. You’re right that these UVC cameras don’t ship with a serial number in the USB descriptor by default, which makes enumeration ambiguous when multiple units are connected. Before pointing you to the tool, could you confirm which OS you’ll actually run the project on and roughly how many cameras are connected at once? If you have Linux handy, what does lsusb -v show for one of the cameras around the iSerial field?
I’ll likely run the project on Linux, but I can use Windows to set the serials if the tool is Windows-only. I have 4 cameras right now. On Linux I checked lsusb -v and the iSerial field is 0/blank for them, and they all share the same VID/PID, so there’s nothing unique to key off. I didn’t save a full dump, sorry.
That matches the known behavior, so no worries about the full dump. The root cause is exactly what you’re seeing: the Arducam UVC cameras don’t include a serial number in the USB device ID by default, so the OS can’t uniquely identify individual cameras when several are plugged in. The fix is the Arducam Serial Number Tool. The software section of the guide is here: Redirecting.... The general approach is to connect one camera at a time, write a unique serial to each unit, then reconnect them all. After that the serials should show up in lsusb -v (iSerial) and you can use them for stable assignment.
Thanks, the link works. I’ll try it on one camera first. Two quick questions before I start: after I write a serial, do I need to unplug/replug the camera for it to be picked up? And will the serial survive power cycles, or do I need to reapply it every boot?
Yes, the camera needs to re-enumerate for the new serial to take effect, so unplug and replug after writing. The serial is stored on the camera itself and should persist across power cycles. If after writing it still doesn’t show up, let me know which OS version you ran the tool on and whether the tool reported success — that’ll help narrow it down.
