Internet - UCTRONICS - Shipment #1000035183 for Order #1000024552 - Model number of the product(s)?
Arducam 5MP 1080p Pan Tilt Zoom PTZ Camera for Raspberry Pi 4/3B+/3 - What hardware/platform were you working on?
Raspberry pi4 - Instructions you have followed. (link/manual/etc.)
5MP OV5647 PT&PTZ Camera Module - Arducam - Problems you were having?
Camera is not detected. - The dmesg log from your hardware?
raspiantoine@raspberrypi:~ $ dmesg | grep arducam
is empty - Troubleshooting attempts you’ve made?
I can send picture of the connection. I have doublechecked the ribbon and everything is OK
raspiantoine@raspberrypi:~ $ cat /etc/os-release
PRETTY_NAME=“Debian GNU/Linux 11 (bullseye)”
NAME=“Debian GNU/Linux”
VERSION_ID=“11”
VERSION=“11 (bullseye)”
VERSION_CODENAME=bullseye
ID=debian
HOME_URL= taken away because not accepted
SUPPORT_URL=taken away because not accepted
BUG_REPORT_URL=taken away because not accepted
raspiantoine@raspberrypi:~ $ cat /proc/meminfo
MemTotal: 3834324 kB
MemFree: 2936412 kB
MemAvailable: 3392880 kB
Buffers: 23072 kB
Cached: 555076 kB
SwapCached: 0 kB
Active: 81016 kB
Inactive: 622768 kB
Active(anon): 1056 kB
Inactive(anon): 203900 kB
Active(file): 79960 kB
Inactive(file): 418868 kB
Unevictable: 58640 kB
Mlocked: 16 kB
SwapTotal: 102396 kB
SwapFree: 102396 kB
Dirty: 0 kB
Writeback: 0 kB
AnonPages: 184380 kB
Mapped: 176256 kB
Shmem: 79320 kB
KReclaimable: 28788 kB
Slab: 55804 kB
SReclaimable: 28788 kB
SUnreclaim: 27016 kB
KernelStack: 3616 kB
PageTables: 5496 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 2019556 kB
Committed_AS: 1222560 kB
VmallocTotal: 259653632 kB
VmallocUsed: 11204 kB
VmallocChunk: 0 kB
Percpu: 688 kB
CmaTotal: 327680 kB
CmaFree: 280704 kB
MemFree: 2936412 kB
Buffers: 23072 kB
Cached: 555080 kB
SwapCached: 0 kB
Active: 81020 kB
Inactive: 622796 kB
Active(anon): 1060 kB
Inactive(anon): 203928 kB
Unevictable: 58696 kB
Mlocked: 16 kB
SwapFree: 102396 kB
Dirty: 0 kB
Writeback: 0 kB
Mapped: 176300 kB
Shmem: 79324 kB
Slab: 55764 kB
SUnreclaim: 26976 kB
PageTables: 5488 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
Committed_AS: 1222564 kB
VmallocChunk: 0 kB
Percpu: 688 kB
CmaTotal: 327680 kB
CmaFree: 280704 kB
raspiantoine@raspberrypi:~ $ cat /boot/config.txt
Raspberry Pi Documentation - Configuration
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
DMT (computer monitor) modes
#hdmi_drive=2
no display
#config_hdmi_boost=4
uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
start_x=1
display_auto_detect=1
Enable DRM VC4 V3D driver
#dtoverlay=vc4-kms-v3d
max_framebuffers=2
Run in 64-bit mode
arm_64bit=1
disable_overscan=1
start_x=1
dtoverlay=ov5647
[cm4]
otg_mode=1
[pi4]
dtoverlay=vc4-fkms-v3d
arm_boost=1
gpu_mem=128
- What help do you need?
How to have it detected?
